Previous in Forum: Hot Galvanized Steel   Next in Forum: chrome options
material selection
08/16/2007 12:23 PM
suggestion can u give some material properties like inconel, cast iron , low alloy steel and standard used related to fabrication of pressure vessel working under elevated temperature ,low temperature and cryogenic temperature? -
Good Answers: 143
Re: material selection
08/17/2007 3:01 PM
You can find some high temperature info at www.hightempmetals.com
08/16/2007 9:01 PM
Not sure if this will help, but you may want to check out Sente Software. They provide either software to calculate materials properties based upon your chemical compositions (and any other specifications you require, such as heat treating temps)...or consultancy whereby you can submit the info you need on a case by case basis and they will give you results. Their software provides lots of physical and thermophysical properties, along with phase transformations CCT/TTT diagrams, and mechanical properties (Stress/Strain curves) for the material types you mentioned... (see: www.jmatpro.com) It's good for known materials as well as new materials/alloy development. You can contact their US Rep to get an online demo from their website.
