Previous in Forum: Aluminum Die-Cast Alloy   Next in Forum: material selection
Engineering Fields - Manufacturing Engineering - United Kingdom - Member - Get things done!
Hot Galvanized Steel
08/16/2007 6:25 AM
Hopefully this is a quick one! At what temperature is it safe to heat Galvanised steel too, before it gives of fumes?
'The truth is out there' The lies are in your head.
Re: Hot Galvanised steel.
08/16/2007 6:41 AM
http://www.webelements.com/webelements/elements/text/Zn/heat.html gives the melting and boiling temperatures. On rising temperature in air it will probably oxidise well before it boils, producing smoke. The presence of Zinc tends to cause errors in the crystal lattices of steels thereby weakening them, which is why welding galvanised steel is verboten, quite apart from the potential health consequences to the operative in so doing.
This computer won't open:
Air Control Pollution Rochester ... but the permissible exposure limit for occupational exposure to zinc oxide in the United States is 5.0 mg/m^sup 3^ respirable dust. www.control-s.org/air-control-pollution-rochester.html
Others might. Happy reading!
08/16/2007 7:36 AM
Cheers, that'll do!
Good Answers: 19
08/17/2007 9:01 AM
I don't have any documented source, but I have a vague recollection it is around 600 deg. F. The zinc coating of galv steel collects oxides from day one, and I understand this is the "smoke" seen, not the zinc boiling off.
BTW, I have seen welded galv stee frequently, and the materials coated with a zinc-rich primer. Could one of you explain the weakening of the base steel that occurs during welding?
Re: Hot Galvanized Steel
08/17/2007 9:22 AM
Both are correct. Zinc starts oxidizing from day one after galvanizing. In humid or wet environments this causes "white rust" which is a visual defect and no way damages the integreity of the zinc coating. The smoke you see at 600 is oxide, the zinc coating will not melt until ~740. Also welding of two galvanized peices of steel does not hurt the steel structure. Galvanizing actually makes a more impact resistant and durable peice of steel in addition to the corrosion protection. The zinc galvanizes in 3 layers, layers one and two are actually a chemical combanation of the zinc and iron. Now that everyone has had a lesson in galvanizing any other relevant information can be found and www.galvanizeit.org which is the American Galvanizers Association.
Good Answers: 19
08/17/2007 9:32 AM
Thanks!
cmorg6 (1); PlbMak (1); PWSlack (1); Ried (2)
