Previous in Forum: Converting Cooking Oil into Biodiesel   Next in Forum: Hot Galvanized Steel
Aluminum Die-Cast Alloy
08/16/2007 4:47 AM
I'm looking for an Alum. die cast alloy. The chemical composition is, Si 0.10, Fe 1.03, Cu 0.011, Mn 2.61, Zn -, Mg -, Al the remainder. It has a high melt of 655*C. D. Roe
Good Answers: 27
Re: Aluminum Die-Cast Alloy
08/16/2007 10:36 AM
Try www.matweb.com and search on the composition.
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
08/17/2007 7:31 AM
Try Machinery's Handbook.
Will give you exact call up
with composition you need.
Dirt is for vegetables. Pavement is for racing.
Good Answers: 12
08/17/2007 1:30 PM
Most common aluminum alloys have a numbering system which defines the chemical composition of the alloy. For example, in making antennas, I use alot of 6061 Al. I will tell my supplier that I need x lengths of 1/4" 6061 rod, and he knows exactly what I am talking about.
I am willing to bet that the chemical composition you describe has a common number, but regretfully I don't have a book available right now which has the information. You might be able to find the info with Google. {Aluminum alloys} maybe?
Note that other metals have similar numbering systems for their alloys. Stainless Steel comes to mind. I believe they use 3 digit numbers though.
Bill
08/17/2007 1:51 PM
The composition does not look typical for die casting process. Conventional wisdom would suggest wide freezing range, low fluidity, propensity for shrinkage. I would love ot hear more on an alloy of this composition related to die casting!
08/17/2007 10:23 PM
Poor alloying mix!
If you must have that, mix yourself in an Induction Mixer -- out of bought scrap.
You have to have a very large scrap dump to choose from.
And you have to have direct-reading Spectrometer to label individual pieces of scrap!
You also need careful Computation of net expected alloy mix.
Bluestone (1); MUKULMAHANT (1); Schrammel (1); Sciesis2 (1); unclefastguy (1)
