Previous in Forum: Panasonic Microwave   Next in Forum: Husqvarna Mower Problem
21 comments
What Is It?
03/29/2017 9:57 AM
sorry cheaters I don't think Google Images will help you this time
give this energy saver your best shot
Re: what is it?
03/29/2017 10:49 AM
this might save you 5%
Re: what is it?
03/29/2017 11:31 AM
HINT
Re: what is it?
03/29/2017 12:27 PM
Well that looks like an aircraft wing. So I am guessing those create vortices in improve wing efficiency? It certainly doesn't look like your original pic at all.
Re: what is it?
03/30/2017 3:13 AM
No its the new LynDoorMat Batterie Charger!
Step into your day with a charged up batterie. Just 150 steps from each familiy member per hour and you are up and running at lunch time!
Re: What Is It?
03/29/2017 12:24 PM
Re: What Is It?
03/29/2017 12:31 PM
That's why it doesn't look like a wing, it's a truck. G.A.
Re: What Is It?
03/29/2017 12:50 PM
it's all about flow separation. I need more data on the plasma avenue before I'd accept it as viable. either way it's interesting
Re: What Is It?
03/29/2017 1:18 PM
cheater
Re: What Is It?
03/29/2017 2:09 PM
Not sure about that, google images didn't help me out with that pic.
Re: What Is It?
03/29/2017 4:36 PM
Some great sleuthing there, Sir Robin!
Re: What Is It?
03/31/2017 2:20 PM
Actually, it was happenstance that I knew the answer because a colleague had sent me that link in an email not ten minutes prior to this posting because he found it very interesting as well.
Re: What Is It?
03/30/2017 6:06 AM
"They are breaking wind. With ions."
Is that what happens when you eat too many statically charged beans?
Re: What Is It?
03/31/2017 2:23 PM
Only when you light them and turn them into a plasma
Re: What Is It?
03/30/2017 6:30 AM
Good, we have free ions by then.
Re: What Is It?
03/29/2017 12:45 PM
Re: What Is It?
03/29/2017 4:24 PM
The "charge" of the plasma is supposed to 'hold' the airflow against the surface and thus reduce turbulence, so as to increase fuel economy by reducing drag.
Re: What Is It?
03/29/2017 4:36 PM
Being a Mopar guy, I am going off topic here, do you own a '70 AAR cuda?
Re: What Is It?
03/29/2017 5:04 PM
if you watched the clip you'd see your premise isn't what they're going for. they're creating wind VS wind to set up a vortex. this creates separation.........reducing drag
https://youtu.be/8zQokKKWBLg
so the plasma creates it's own wind right at critical points in the very front of the truck so the air will separate and not stick so much to the sides of the truck, reducing drag. it's all explained in the clip
Re: What Is It?
03/30/2017 3:46 PM
If that plasma has a net charge that isn't completely neutralised by contact with the truck, that truck is going to build up a considerable charge over time. How do they plan to neutralise that charge? Drag a chain?
Good Answers: 179
Re: What Is It?
03/30/2017 7:20 AM
It still looks like a new type of cheese grater to me.
So, I'm to assume that this disrupts or enhances the "boundary layer" layer effect?
Register to Reply 21 comments
70AARCuda (1); Andrew Westman (2); Brave Sir Robin (3); CaptMoosie (1); Fredski (7); gutmonarch (1); IdeaSmith (1); JPool (4); Randall (1)
