Previous in Forum: International Summer School – Advanced Urban Design   Next in Forum: Best Electronic Manufacturing Services in USA
Aviation Light
03/30/2017 3:47 AM
To send proposal , I need information and support from manufacture aviation light with spec below
TECHNICIAN DATA RUNWAY APPROACH LIGHTING CONTROL UNIT
Power supply : Power circuit 400VAC 3Ph 50/60Hz Power consumption : ~ 1,4kVA, asymmetric load, main load at L1/L2
Fuse : Internal fuse automat 10A fuse characteristic K
Communication interface remote control : 2x CAN- BUS, 2x MODBUS/RTU, 8x 24VDC Input parallel interface, 5x 24VDC Output parallel interface Communication interface comfort local control : 12C Communication interface service computer : USB Communication interface flash lights : 2-wire power line
Environmental temperature : -25 ~ +45 DegC Relative humidity, not condensed : 10 - 90% International Protection class : IP 43
Altitude over NN (operation) : -100 ~ +2500m Housing : Metal housing wall mounted Dimensions : 500x500x210mm (BxHxD) Weight : 22kg
Qty : 2 Ea
POWER DISTRIBUTION UNIT
Power circuit : Primary circuit 400VAC 50/60Hz, Primary circuit 36VAC (SELV)
Data communication : Primary circuit Powerline, Primary circuit Powerline (SELV)
Environmental temperature : -40 ~ +55 DegC Relative humidity, not condensed : 10 ~ 100% International Protection Class : IP 68, 1m immersion depth
Altitude over NN (operation) : -100 ~ +2500m Housing : Full potted PU housing
Dimension : 142x192mm (DxL) without cable Weight : 6,5kg
Qty : 2 Ea
FLASH LIGHT
Power supply : 36VAC, 50/60Hz (SELV)
Max. Power consumption : EL IL 20, VA 20VA Communication interface control unit : 2-wire power line (SELV)
Environmental temperature : -25 ~ +85 DegC Relative humidity, not condensed : 10 ~ 100% International Protection class : IP68
Altitude over NN (operation) : -100 ~ +2500m Dimension (Packaging) (WxHxD) : EL 300x300x190mm, IL 310x310x190mm
Weight : EL 7.5kg, IL 6.9kg
LED power (SFL configuration settings general) Standard (EL dimmed) High : EL 12500 cd eff, 21000 cd eff, IL .7500 cd eff, 7500 cd eff
Nominative life time : > 50000H Color temperature, typical : 4125K
For harmonization of the visual impression the use of double inset flash lights is recommended
STD :
FAA :L-849 a-e/AC-150/5345-51,
ICAO Annex 14 Vol 1/5.3
Quantity : 4 Ea
Include : Brochure
Re: aviation Light
03/30/2017 3:50 AM
So why wake up all the sleeping beauties here? Get on the phone to the equipment manufacturers directly.
Reply to Forum Thread
