Previous in Forum: optimization /pressure vessel   Next in Forum: FREE Grinding Video Online
Wire cut EDM
08/16/2007 3:11 PM
hi all
I was wondering is there a formula to calculate the machining time for a workpiece cut on a wire cutting machine similar to that for turning and milling
t= l / s*n
it is important for estimating the cost of machining.
If any body can help me, i would be grateful
thanks alot
Re: Wire cut EDM
08/16/2007 10:23 PM
We have an EDM machine at work and the wire feed rate is proportional to the finish that we are trying to get on the part. Plus we need to know the material that you are cutting as Stainless steel and carbide are different feed rates. Please advise what machine you are using or it's capacities. I will look up the information if you will supply the material, finish and thickness of the cut. Ric
Anything can be made, sometimes at great expense, resulting in greater satisfaction, :)
Re: Wire cut EDM
08/23/2007 4:21 AM
Dear Sir
Good Morning!!
We would like to introduce ourself.
We are a manufactory of EDM WIRE & Zinc Coated Wire in Taiwan.
We would want to know whether you interested in our goods.
Our factory was established since 1988.
Now our company had 30 production lines and cashing machine.
We are an integrated manufacturer, controlling the entire wire manufacturing
process from cashing to final drawing.
So we think our price will be more compition than other company.
We also have a good quality.
We have some of OEM companies. Who come from JAPAN , EUROPE & USA.
If you interested in our goods. Please feel free to contact us.
( PS. We also sell big size. If you need it. Please contact us. )
Best Regards;
Candy Tsai
JIA BAO METAL CO., LTD.
NO.542-2 SEC 2 , HETZUEN N.RD.,
JUNGLI CITY, TAOYUAN HSIEN,
TAIWAN, R.O.C.
TEL: 886-3-4623000
FAX:886-3-4333866
MOBILE: 886-910-688-109
Re: Wire cut EDM
08/17/2007 5:25 AM
Dear RicinCinci
thanks alot, actually this machine is used to cut tool steel for sheet metal dies,
So i understod that if i know the feed rate which depends on the material and the surface finish, all I will do is to divide the length of the contour by the feed rate to get the time required for machining!
am i right?
Re: Wire cut EDM
08/17/2007 9:32 AM
That's right.
Re: Wire cut EDM
08/17/2007 11:40 AM
Correct.
Also figure in the number of times that the system will recycle over the cut to make the finish.
Typically the EDM will make several passes with the wire tightning to make the finish and the final size needed. We have a program on our computer that will tell you the time of the run from the drawing made to make the part. Check your system and see if the run time is an option from the control pannel or the input program.
Ric
Re: Wire cut EDM
08/17/2007 8:32 AM
A lot of parameters are there for Wire cut EDM
Tool metal, Job metal, votage, current applied, Job RoughnessInsulating medium, temperature,
position,[flat,wall,ceiling], Job area , shape depth of cut, MRR
Please refer American Society of Metals Hand book
Engg Design, 150 hp/1000 cc, 1600 hp/2400 cc F1; 600 kph MonoRail,Ferry,VLCC
Engineering Fields - Mechanical Engineering - Member
Wire cut EDM
08/28/2007 8:12 AM
for a 25 mm thick hardened die steel plate, you can assume 1mm/min cutting speed for roughing, 0.8mm/min for finishing & 2-3 mm/min for providing relief. the speed is directly proportional to the thickness. this does not include set up time. i have found this formula quite accurate & you can save upto 10% time
Register to Reply 7 comments
Anonymous Poster (1); appan (1); kik0kik0 (1); Labyguy (1); RicinCinci (2); venkat (1)
