Previous in Forum: PLC & CNC   Next in Forum: Compressor rotation
11 comments
D.G. - P.F.
08/17/2007 4:03 PM
Why we does not use capacitor bank while D.G. running
TARGET - Where many stop thinking, some start from there. Tenacity to get target helps to WIN.
Good Answers: 42
Re: D.G. - P.F.
08/18/2007 12:19 AM
D.G. = ????
Good Answers: 42
Re: D.G. - P.F.
08/18/2007 11:52 AM
DG = Deisel Generator?
Re: D.G. - P.F.
08/18/2007 2:28 PM
Diesel Generator
when we start plant on D.G. that time we Tripp the Capacitor bank. if we does not tripping bank than our main supply incomer Air Circuit Breaker Tripp.
Re: D.G. - P.F.
08/18/2007 2:30 PM
Yes Diesel Generator
when we start plant on D.G. that time we Tripp the Capacitor bank. if we does not tripping bank than our main supply incomer Air Circuit Breaker Tripp.We can not improve d.g. p.f.? Our D.G. is 1000 KVA & P.F. is 0.80p.f.
Re: D.G. - P.F.
08/18/2007 7:02 AM
You are using Capacitors when the EB supply is on probably because of Low PF.However with Diesel generating set the PF is normally 0.86 and hence u are not connecting the capacitor bank.If PF Is low with DG supply on then u need to use the capacitor bank .I presume you are using a centralized capacitor bank.If Individual capacitors are used on each equipment it may still be used .Other reason could be u may be using a HT capacitor bank centrally and DG being LT it may be cut off .Any way whether DG Or Mains supply PF determines use of capacitors.U may have to give more details to go in Depth
Re: D.G. - P.F.
08/18/2007 2:42 PM
Thank You For replying
Sir actually we have 1000 KVA D.G. When we start the plant on D.G. that time suppose we does not Tripp the capacitor bank than our main Air Circuit breaker tripped so we always off the bank when our D.G. started. & its see in many company's they also doing like that.
Good Answers: 42
Re: D.G. - P.F.
08/19/2007 3:35 AM
Does your DG come up to speed then transfer onto the system?
If so, and there will be a significant inrush to the caps.
Re: D.G. - P.F.
08/20/2007 7:12 AM
We use capacitor banks to improve the power factor. These banks are connected in parallel to the supply at mains OR can be connected with individual inductive load. Usually connected at mains. These operate with automatic PF corrector relay which senses the pf & accordingly operates the capacitor banks to improve the pf. Capacitors draw leading current & are capacitive load on the system. These should never operate on DG as this will be an additional load to DG. Thus you would not be able to utilize full output of DG. The PF of DG set can be improved through an AVR. If you trip your Capacitor bank on DG supply manually, then you can get your control wiring changed so that whenever you run a DG set, capacitor bank will not come into play. It will only operate on State electricity.
Hope your querry is solved
Ashish Gupta
Ashish Gupta
India - Member - New Member
Re: D.G. - P.F.
08/19/2007 11:04 PM
Alternator of Diesel Generators systems are rated for 0.8pf Lag. We can not add uncontrolled reactive ( Capacitive ) compensation for DG. If in case of power factor of system goes to leading, then there is every chance failure of windings. hence usually all capacitor banks will be provided electrical interlocks to protect the DG.
Pls note that kW output from the DG is at 800kW, Only we can get the KVA benefit
if we add capacitors. Detailed study of the system is very important before we do take any changes in system.
Nothing is impossible, Impossible is nothing
Re: D.G. - P.F.
09/28/2007 10:19 PM
What will be the effect of capacitor bank on DG engine. Will it overload the engine resulting in overheating / other problems.
Re: D.G. - P.F.
08/20/2007 7:07 AM
Ashish Gupta
Register to Reply 11 comments
Anonymous Poster (1); ashuashi (1); balazii (1); GW (3); hara143 (1); nesubra (1); Nishant (3)
