Previous in Forum: Cryogenic Computing   Next in Forum: Recent Elon Musk Ted Talk
The Engineer
Good Answers: 129
Einstein's Equivalence Principle Works for Atoms in Superposition
05/01/2017 7:59 AM
I came across this article describing a pretty cool experiment and I thought I'd pass it along. Here is the article:
Key Einstein principle survives quantum test
Particles with mind-bending quantum properties still follow a standard gravitational rule, at least as far as scientists can tell. The equivalence principle — one of the central tenets of Einstein’s theory of gravity — survived a quantum test, scientists report online April 7 at arXiv.org.
In Einstein’s gravity theory — the general theory of relativity — gravity and acceleration are two sides of the same coin. According to the equivalence principle, the gravitational mass of an object, which determines the strength of gravity’s pull, is the same as its inertial mass, which determines how much an object accelerates when given a push (SN: 10/17/15, p. 16). As a result, two objects dropped on Earth’s surface should accelerate at the same rate (neglecting air resistance), even if they have different masses or are made of different materials.
One of the first reported tests of the equivalence principle — well before it was understood in the framework of general relativity — was Galileo’s apocryphal experiment in which he is said to have dropped weights from the Leaning Tower of Pisa. Scientists have since adapted that test to smaller scales, swapping out the weights for atoms. In the new study, physicists went a step further, putting atoms into a quantum superposition, a kind of limbo in which an atom does not have a definite energy but occupies a combination of two energy levels.
Manipulating rubidium atoms with lasers, scientists led by researchers from Italy gave the atoms an upward kick and observed how gravity tugged them down. To compare the acceleration of normal atoms with those in a superposition, the scientists split the atoms into two clouds, put atoms in one cloud into a superposition, and measured how the clouds interacted. These clouds of atoms behave like waves, interfering similarly to merging water waves. The resulting ripples depend on the gravitational acceleration felt by the atoms.
The scientists then compared the result of this test to one where both clouds were in a normal energy state. Gravity, the researchers concluded, pulled on atoms in a superposition at the same rate as the others — at least to the level of sensitivity the scientists were able to probe, within 5 parts in 100 million.
Article Continues Here
Re: Einstein's Equivalence Principle Works for Atoms in Superposition
05/01/2017 10:01 AM
Five parts in 100 million is good enough for me. GR wins again. It makes no difference what it is, its path in a gravity field is determined by the geometry of space-time.
05/01/2017 12:14 PM
I would tend to agree. I have not read the full article as yet, but intend to. Are we talking nuclear spin states in superposition, or electronic energy states?
05/03/2017 6:27 PM
Electronic energy states, apparently.
"The Einstein Equivalence Principle (EEP) has a central role in the understanding of gravity and space-time. In its weak form, or Weak Equivalence Principle (WEP), it directly implies equivalence between inertial and gravitational mass 1 . Verifying this principle in a regime where the relevant properties of the test body must be described by quantum theory has profound implications 2, 3. Here we report on a novel WEP test for atoms. A Bragg atom 1 arXiv:1704.02296v2 [physics.atom-ph] 12 Apr 2017 interferometer in a gravity gradiometer configuration compares the free fall of rubidium atoms prepared in two hyperfine states and in their coherent superposition. The use of the superposition state allows testing genuine quantum aspects of EEP with no classical analogue, which have remained completely unexplored so far. In addition, we measure the Eotv ¨ os ratio ¨ of atoms in two hyperfine levels with relative uncertainty in the low 10-9 , improving previous results by almost two orders of magnitude 4 . "
https://arxiv.org/pdf/1704.02296v2.pdf
05/02/2017 4:56 PM
Einstein's Equivalence Principle meets Schrödinger's Ambivalence Principle.
Big Al: 1, Erwin: 0.
Register to Reply 4 comments
Andrew Westman (1); James Stewart (1); Rixter (2)
