Previous in Forum: Capacitive Power Factor   Next in Forum: Overhead Line Testing
11 comments
Vector Parallel to the Line
05/28/2017 1:01 AM
Hi Guys! I was doing a vector math problem since we have this module in this semester in math,I'm an electrical engineer student don't get me wrong and I gat stuck on how to find the vector parallel to the line.
The question is : Determine if the plane given by -x+2z=10 and the line given by r=(5,2-t,10+4t) are orthogonal, parallel or neither.
Now I have already found the normal vector as the first step,but also I have to find the vector that is parallel to the line so as that I can cross it with the normal vector to prove if it they are parallel to each other.
Thank you
Re: Vector parallel to the line
05/28/2017 1:21 AM
05/28/2017 1:34 AM
Your exact same problem is solved here in Example 2.
05/29/2017 8:43 AM
I know,but this is the part where I got stuck
"Example 2 Determine if the plane given by and the line given by are orthogonal, parallel or neither.
Solution
This is not as difficult a problem as it may at first appear to be. We can pick off a vector that is normal to the plane. This is . We can also get a vector that is parallel to the line. This is .
Now,how did he get the parallel vector? The vector V=(0,-1,4)
05/29/2017 10:41 AM
Think about the vector ⟨5, 2-t, 10+4t⟩: 5, 2 and 10 are just offsets.
Let's consider a simpler case: y = mx + b, a line expressed in slope-intercept form.
Say we've got two lines:
y = 5x + 2
and
y = 5x + 8
Are they parallel even though their y-intercepts are different? Sure they are, because their slopes are the same. Changing where they intercept the y-axis doesn't change this fact. All b does is translate the line vertically. The lines are still parallel. And since we're only interested in whether they're parallel or not, we can ignore b entirely to get y = mx.
In the three-dimensional case we have here, it is no different except that the idea of slope is little more complex, but it is still a coefficient on each component just like 'm' is for the slope-intercept line. Similarly, adding or subtracting a displacement to each component does not affect it's 'slope', only its displacement. And since only its 'slope' figures in determining whether it is parallel to another vector, we can ignore the displacements entirely. All they do is just move the vector around, they don't affect its 'slope.' Only the coefficients do, and since this vector parameterised, we can plug in any value we want for 't' and so we can fix t = 1 and voila! ⟨0,-1,4⟩! Dig?
05/29/2017 11:32 AM
Thank you,nw I get it.So u can plug any number in t to get other points,I'm I right?
05/29/2017 11:35 AM
t = 1 gives you the 'raw,' unscaled vector, its most convenient form.
Compare two vectors, one with the offsets and one without, and see for yourself if they're parallel.
v1 = ⟨5, 2-t, 10+4t⟩
v2 = ⟨0, -t, 4t⟩
and t = 1.
Try it.
05/28/2017 7:47 AM
As t increases from zero to one, r changes by -j + 4k. That's your vector parallel to the line.
Re: Vector Parallel to the Line
05/28/2017 4:40 PM
Ah, that explains your previous questions (your handle is rather misleading).
Is this not explained in your text book? Have you tried to actually draw the example out to help you visualise the question and answer?
05/29/2017 1:23 AM
This is high school level maths. I really doubt you got trough the selection process fon an Engineering University withot knowing hiw to solve linear equations.
Building the future!
05/29/2017 2:00 AM
Well, that was certainly helpful.
05/29/2017 8:40 AM
Nobody's perfect,you cannot remember everything from highschool mate
Register to Reply 11 comments
Andrew Westman (4); Ivanov327950 (1); jack of all trades (1); Rixter (1); SolarEagle (1); Techgenius (3)
