Previous in Forum: Vector Parallel to the Line   Next in Forum: Grounding for NGR of Transformer
32 comments
Overhead Line Testing
05/28/2017 2:05 PM
Hi
We have just constructed a New transmission line having Rail conductor 132kv double vertical circuits line, and now we performing HI-POT 80kv test which is the common practice in my country before line energize , when I perform the test in the small section of the line (Hi-Pot phase to ground) the maximum voltage reach and stand 60kv and in next portion its goes in 8kv only, what is the reason, is this device fault ? or line have some fault but why its even goes 8kv ? if line have some fault ?
Re: overhead Line Testing
05/28/2017 2:39 PM
My guess would be broken or dirty insulators. Maybe if you run the test at night, you might be able to see the fault.
05/28/2017 4:17 PM
Words fail me sometimes, what the heck are people being taught now days that simple analysis and fault finding techniques are beyond some people and have to be outsourced.
05/30/2017 6:06 AM
...to anonymous strangers who cannot see the installation, have no financial interest in it, and, at the time of writing, have no idea where on the planet the problem is located.
It is absolutely astonishing.
05/28/2017 3:37 PM
Your electric utility company may benefit from using a DayCor camera. If you've any arcing, excessive corona in your system this camera will find it. (I am not connected with DayCor's mfr in any way)
05/31/2017 5:22 PM
I like the Rail system they have, but may not be sensitive enough to detect hipot discharge, with generally limited current available. I tend towards IQ Post 24, where you just put the boots to it, and back-check with your DayCor, if the insulator string doesn't flash over. The Preventive Maintenance possible with that, combined with thermographic data, would make you both efficient and reliable.
05/28/2017 4:13 PM
What else could it be but your insulators?
Check your insulators.
05/30/2017 10:52 PM
There is a LOT of air to be checked.
05/30/2017 11:28 PM
I think I found his problem
He said overhead line testing, right?
Good Answers: 70
05/28/2017 7:36 PM
I too would post this question as an "AP"! Common sense would tell you are not qualified to work with HV, but stupidity tells you to continue on and go to an anonymous forum and seek answers!
Hopefully, you live to tell about it!
05/28/2017 8:10 PM
I am starting to wonder if this is partially a cultural thing where some people are just too afraid to lose face (or something similar) by asking a more senior engineer on site a question and so resort to asking on online forum instead.
We are not talking toys and games here. The MW level power generation and high kV transmission-level power line selection and fault finding questions like these asked on CR4 recently should NOT be this common.
What's going on out in the industry that could be causing this? Is this common and CR4 is just becoming more popular and attracting more of these questions.
Good Answers: 70
05/28/2017 8:30 PM
This is becoming too common here on CR4. But if you think about how some countries string their lines, it's amazing that the magic smoke hasn't appeared sooner, taking the continent's power grid out of service
05/28/2017 10:09 PM
I tend to agree - it may be a cultural thing. Could also be they work for a harsh superior who's unapproachable and so feel safer asking elsewhere anonymously.
There are also areas in the world where professional training isn't accessible for any number of reasons, and so people are trained by being thrown to the wolves. I suspect this is the case more often than not.
I don't think it'll hurt us too much to help these folks out. There was a time when I knew diddly squat about my field (and about many, many subjects I still do), and so being able to ask someone was a huge help. Sometimes all I needed was just one tiny little key piece of information and the rest of it all fell into place.
The way I look at it, I give them credit for asking. The ones who don't ask, who think they know what they're doing (but don't really, and don't know that they don't know), are the really dangerous ones. Those and the ones who come here repeatedly with questions but don't learn anything. We've a few of those, yes.
Anonymous Poster #2
05/29/2017 3:51 PM
You didn't belittle the original poster nor actively insult him or her nor try to degrade their environment. A breath of fresh air. Thanks.
Good Answers: 70
05/29/2017 12:38 AM
Good Answers: 80
05/29/2017 8:30 AM
Do you have any power factor compensation capacitor on the line?
You didn't specify if your test was conducted with AC or DC.
05/29/2017 2:03 PM
it is DC
05/29/2017 3:41 PM
On a (test isolated) section of 132kV overhead transmission line? Are you sure? Can you provide a link of an example.
Good Answers: 27
Re: Overhead Line Testing
05/29/2017 9:54 AM
AC or DC Hi-Pot? There may be more than "the next section" in the test circuit unless it is isolated or sectionalized in some manner. You are likely seeing the effect of charging current over a much longer section of the transmission line than you realize.
05/30/2017 4:39 AM
The answer to the three questions is "It doesn't matter". The test failed. End Of.
So the only thing to do is to investigate why the test failed, carry out an appropriate remedy, and repeat, until the installation passes the test. It could be anything.
As the installation and the test equipment cannot be seen from here, the investigation, and the remedy/ies, are all in the domain of Anonymous Poster #1.
05/30/2017 3:04 PM
Test is not failed, its just not upto the mark ., as leakage current in 40mA at 80kv or some times leqkage current is more then 40mA but voltage only 1 or 2kv and equipment get tripped, and this is also happening specially in night .
05/30/2017 3:15 PM
Then what's different at night do you think? Increased moisture in the air perhaps causing a path to ground through a faulty insulator? <hint> <hint>
05/31/2017 4:40 AM
Why bother testing at all? Why not just energise and be done with it?
06/01/2017 9:12 AM
<...its just not upto the mark...> So which side of the pass/fail boundary is it, then?
Good Answers: 70
05/31/2017 12:23 AM
Too bad "they" (he/she) posted as an "AP", we have no clue about where in this world they reside in and what climate they're dealing with, moisture, dust, bird droppings- the list goes on ...... Sounds like a homework question to me
05/31/2017 2:34 AM
Hmm...I dunno. Homework questions are usually a bit too 'tidy' and clear-cut. I tend to suspect this is a real, in-the-field situation.
05/31/2017 9:31 AM
Rail conductor? Can you elaborate? AAAC ACSR, HTLS, but rail conductor?
1. 80KV is not the right pressure test voltage for 132Kv by any means. Try 198Kv minimum for 1 hour per line section and all you might do is test some insulators.
2. The 8KV (52kV drop), is due to the line length.
3. Do not take the results as serious tests, as the test you are trying to perform is totally pointless.
Just connect the line to the busbar supplying 132kV and leave it to soak for 24hrs. You do not have a sufficiently large pressure test unit (Hi Pot Tester), for the line length you have. If the line holds on 132kV for 24 hrs with no tripping, you can then energise the line for load.
Seriously, you are testing nothing, proving nothing at 80kV, on a long line, double circuit. Your 80Kv is only good for pressure testing 33kV cables up to 6km long.
06/05/2017 1:30 PM
thanks for the reply
06/02/2017 9:38 AM
Is it in all phases?In both circuits?Try Isolating the sections,I mean disconnect the jumpers at angle towers and take only a section at a time.Weather makes a difference but values are very low even otherwise
06/05/2017 1:32 PM
i did this , now line only 2km in length and insulators also cleaned but leakage current is too much and at night no voltage applied ? not more the 1kv
06/05/2017 1:55 PM
So above 1kV DC power, you exceed the current output rating of your hipot set (?).
As asked before, do all 3 phases show the same behavior?
I've never hipot tested an open line. Insulated HV cable, yes, to prevent excessive and perhaps un-repairable damage to insulation/stress cone, or prevent a fire in the middle of a cable tray, in the case of pulling/install or manufacture defect.
Risk of excessive or consequential damage beyond blowing apart or flashing an insulator string you should be able to confirm & evaluate, and decide whether to energize at full voltage,
Isolate to smaller section, one that you know you can charge successfully,
Or get a bigger hipot.
Anonymous Poster #3
06/06/2017 2:35 AM
Just try charging the line with rated voltage.See whether it stands.At best Breaker will trip and may be the bad insulator show up.By the way Is it a Tee Off Line?
Good Answers: 116
06/09/2017 1:42 PM
Seems elementary but...
Your 80 kV tester may have enough current to test one insulator or transformer but not miles of line - the first line section you tested may be short and the next long.
Tell us the line length and test set current capacity @ 80 kV and maybe a line guru will appear.
Reply to Forum Thread 32 comments
67model (1); Andrew Westman (4); Anonymous Poster (6); Bluestone (1); Brave Sir Robin (1); dj95401 (4); IQ (1); jack of all trades (5); marcot (1); nesubra (1); PWSlack (4); Rixter (1); rwilliams (2)
