Previous in Forum: Building a Meat Locker for Deer Season   Next in Forum: Compressor Full Load Test
Inward Heating of Metal Former
08/20/2007 4:14 AM
In Nitrile Latex Gloves manufacturing the dipped gloves loaded on Aluminium Former fitted on the metal bar are passed through a series of 7-9 ovens for drying and curing of the coating of the gloves .But this heating is outward conventionally. Is it technically and productionally possible to use such ovens but using hot air inside the former to save gas consumption,cost and curing time ?
Pathfinder Tags: Inward Heating
Re: Inward Heating of Metal Former
08/20/2007 6:52 AM
My gut feeling is that it may be theoretically possible..it would be horribly complicated and unreliable to actually impement.
Maybe electrically heating the formers?
But what exactly is the drying/curing process? is it just heat or does it need the airflow.
My guess is the best way forward is to try and minimise your heat loss, re-cycle the hot air from one oven to next. Keep it simple..
(Not my field of expertise so I reserve the right...blah..blah..blah)
Good luck
08/21/2007 10:29 AM
The formers would seem to be acting like a heat sink during this process to keep the gloves from absorbing too much heat from the hot air... if you instead heated the formers, you would have to pulse the heat flow, via a hot liquid or something to keep from melting the latex. All together, Del is right... It's possible - but far more complex, error prone, expensive to implement, and at the end of the day may not save any energy or money once all costs (increased maintenance, etc.) are considered.
Register to Reply 2 comments
You might be interested in: Safety Gloves, Welding Gloves, Laboratory Ovens
