Previous in Forum: Liquid Rotor Starter   Next in Forum: Matching Speakers with Amplifiers
Advanced Solenoid Driver
08/20/2007 7:39 AM
Hi there!
Anyone aware of a proportional solenoid valve driver with adjustable dithering (amplitude, waveform, frequency), which can be set using some kind of standars communication interface such as RS232, CAN, USB, whatever? I have only found drivers where these values can be set with a potentiometer, but I would like to set up a user interface in National Instruments LabView where the operator can set up these parameters on the screen.
Thanks!
Good Answers: 54
Re: Advanced Solenoid Driver
08/20/2007 7:55 AM
I don't know about RS232, CAN, USB or others, but Burkert sells proportional solenoid valves that operate with 0 to 20mA, 4 to 20mA or 0 to 10V signals.
08/20/2007 10:27 AM
http://www.pwmcontrols.com/
United Kingdom - Member - Member
08/20/2007 10:41 AM
We have a conveyor controlled by an invertor which allows you to set the speed with an external pot. In order to allow the user to set the speed from the control screen I put a d to a convertor module in the plc and connected the output across the terminals where the pot would have gone.
Maybe this could work for the stuff you have already found
Al
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
Bolton_Alan (1); Duce (1); Vulcan (1)
