Previous in Forum: Electromechanical Frequency Converter   Next in Forum: Circuit Design for a Single-Phase Motor
Cable Selection
08/22/2007 1:20 AM
Hi Guys, can some one help me with any standard or thumb rule calculation for selecting the cable based on current rating?? ofcourse for both copper & aluminium...
Re: Cable Selection
08/22/2007 3:28 AM
Check out the current edition of the Wiring Regulations issued by the Institution of Electrical Engineers. Though applicable to the UK its contents can be applied to many other parts of the World.
Re: Cable Selection
08/22/2007 8:37 AM
Good answer, read the regs of you country! The rule of thumb is:-
Use your thumb to turn the pages!
Good Answers: 42
Re: Cable Selection
08/22/2007 4:03 PM
It is so simple by the time you waste energy on surfing internet contact your nearest cable dealer .All cable manufacturers are providing you this information free of cost.
Ireland - Member - New Member Engineering Fields - Energy Engineering - New Member
Re: Cable Selection
08/22/2007 7:21 PM
Here in New Zealand we have a free program from General Cables called Gencalc which is very useful for NZ conditions. The restrictions are well documented in the help section and should be read carefully.
http://www.generalcable.co.nz/new_zealand/download_genCALC.htm
The only rule of thumb you should ever use is not to get it between the nail and the hammer. I keep mine in my mouth where it can't cause trouble!
I love deadlines; I love the whooshing sound they make as they pass by. - Douglas Adams
Good Answers: 54
Re: Cable Selection
08/23/2007 12:17 AM
Yep, ask the local cable bloke or sparkie.
Cables get current ratings to allow for the fact that the heat dissipated by the conductor will heat up the surrounding insulation and eventually degrade it. So, the size of cable needed is dependant upon the actual heat generated (i^2RT), the way it's laid (in fresh air or bundled with lots of others inside an insulating cover) and the type of cable/insulation (ie PVC insulation or mineral insulated). Jeff
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Re: Cable Selection
08/23/2007 11:43 AM
The following link takes you to a table of American Wire Gage specs:
http://www.powerstream.com/Wire_Size.htm
You can lead a horse to water but a pencil must be lead.
Register to Reply 6 comments
BabyGuinness (1); ffej (1); maxmutant (1); Mr. Truman Brain (1); PWSlack (1); V.I.Abraham (1)
You might be interested in: Cable Laying Services, Cable Assemblies, Cable Trays
