Previous in Forum: IGC and ELC   Next in Forum: Motors for Zone 2 in Process Plants
Constant Current Source
08/23/2007 7:25 AM
hello! I am an electronics tech. and want to design a circuit of constant current source for 1mA at 5v supply voltage. Load range is from 5kohm to 10-ohm. Circuit should have minimum components, not using any ic. Please help me. Thanks, Rana Tahir
ALLAH knows better.
Re: Constant Current Source
08/23/2007 7:42 AM
Well without any accuracy figure quoted I would just use a couple of diodes a transistor and two resistors.
2 diodes in series to bias the transistor base and a resistor in the emitter of about 620 ohms, with 0.6 approx volts across it will give a collector current of approx 1 mA.
This would be a current source or sink depending on whether you use a NPN or PNP transistor....
John
08/24/2007 1:10 AM
Thanks so much sir, I shall try it.
ALLAH knows better.
08/23/2007 8:05 AM
How accurate do you need?
A 1N5297 is a 1mA CCD (constant current diode). +/- 10% I think. You can get CCDs in lots of values and they only need about 1 Volt of overhead.
Another option is to build your own from a JFET and a resistor ( that is what a CCD realy is).
Third option is to use an LM137 Voltage regulator configured as a current source. It requires the LM137 and one resistor.
08/24/2007 4:06 AM
Same method as John's, there's a picture here: http://cr4.globalspec.com/comment/26532 , but you'll have to change the zener to two diodes and reduce the value of the resistor, again, as John said.
Register to Reply 4 comments
Electroman (1); PLM NY (1); rana tahir mahmood (1); Randall (1)
