Previous in Forum: Pour Monitoring   Next in Forum: Calculation of accuracy for digital multimeters
How to provide feedback for inverter?
11/23/2005 8:26 AM
olusola olabisi writes:
I like what you guys are doing. When I found your site to be that helpful,I have given it to my friends. I have just submitted a story about the problems I am facing with my inverter. I am an engineer by profession. I an inverter circuit I designed using CD4047 as an oscillator, the output voltage normally fall at different loads. To solve this problem, I know that feedback must be provided. Please can anybody tell me the procedure for solving this problem? If possible, can you provide a circuit diagram?
feedback to the Inverter
11/24/2005 10:36 PM
Hi, you have to increase in your power source. As P=VI, in your case P is constant (or may be some limitation),you are increasing load, means increase in current naturaly voltage will drop. you can take an out put current signal and compare it with your set value and give that eror signal to the firing pulse generator circuitory. It will limit you output current and hence maintain output voltage. Hope it will solve your problem.
Friends are the angels, who lift us to our feet when our wings have trouble remembering how to fly.
Re:feedback to the Inverter
11/26/2005 2:25 PM
thanks for the professional idea you gave to me. i will try it exactly the way you suggested. please, i will really appreciate any further assistance you can still provide.
TL494
11/28/2005 9:42 AM
the tri-inverter oscillator is known as the poor man's oscillator for a reason, it doesn't give you much to work with. That would be a good modulation source, but for the pulse/driver circuitry, I have had more success with the TL494, a pulse width modulation chip. It has two diode steered operational amplifiers to help with your load sensative feedback issues.
Anonymous Poster (1); halcyon_m (1); Sonu (1)
