Previous in Forum: Automation Designer   Next in Forum: Musical Keyboard Chip
Capacitive load to DG set
08/24/2007 2:10 AM
What will happeen if we connect capcitor bank to the DG set along with Inductive load of a plant
Re: Capacitive load to DG set
08/24/2007 8:32 AM
Hi
Already DG set P.F. define .80 if u connect capacitor than its harm to Alternator winding.
TARGET - Where many stop thinking, some start from there. Tenacity to get target helps to WIN.
Good Answers: 42
08/29/2007 1:17 PM
What is the idea of your connecting capacitor bank in your power output of generator? If it is power factor improvement to reduce KVAR ,then have a regular check of PF and find the appropriate capacitance required for your load by trial and error method . You must keep the PF normally 0.9 .The most appropriate technical solution is to install automatic power factor correcting (APFC) unit attached .When the inductive load is cut off, the system may go to leading power factor resulting in loss of power KVAR . So before connecting Capacitor bank install PF meter and monitor or install APFC.
You might be interested in: Inductive Couplings, Capacitive Proximity Sensors
