Previous in Forum: Welding-HAZ Problem   Next in Forum: material
9 comments
Compressed Air Reservoir Fill Time
08/28/2007 2:54 AM
Hi all,
I have a query that has almost been answered within these forums however I'm still left with an eyebrow raised and am hoping someone can relax it !
I am trying to determine a ballpark figure of required air flowrate based on a 2 second fill time of an empty 160L reservoir with intial pressure at atm from a (effectively infinite capacity) compressed air header at 700kPag. The ultimate aim is to compute the size of connecting pipe that is required to do this (based on choked conditions).
What I have attempted to do is use the formula Q = [{P2 - P1} x V] / {P0 x T } Normal M3 / Min (credit to raviamdekar) to determine the flowrate however, I'm not sure how accurate this will be as the flowrate determined will be "free air discharge" and not under pressure as is in the pipe.
Aside from using differential equations can anyone recommend any other possible means of doing this or perhaps suggest how I should use the above formula ?
Any information would be greatly appreciated,
Kim...
Re: Compressed Air Reservoir Fill Time
08/28/2007 3:02 AM
I'd say do a few calculation based on 'empty', '1/4 full' 'half full' '3/4 full' plot 'em, join up the dots...
Everyone knows I hate maths! Unless you are into the differential stuff this will get you close enough for jazz. I'll bet any amount of calculation won't get you very close.
I'd say use the biggest convenient pipe and choke it down if you want to slow up the fill. Probably as quick to try as to calculate!
Have fun (I reserve the right to be of no help whatsoever)
08/28/2007 3:08 AM
Ha... Thanks nonetheless Del,
You're actually right up with my line of thinking - I hate maths and I have tried joining the dots to avoid it !!!
Cheers,
Kim...
Location: Somewhere in the hills of Pennsylvania, I think.
08/29/2007 1:05 AM
Great idea to use a large diameter pipe and choke it. Use a couple of ANSI flanges on the pipe and bolt the choke between them. Makes changing the choke very easy.
I'm somewhere between the age of thirty-something and Alzheimer's. I just can't remember where!
Good Answers: 19
08/29/2007 11:26 AM
I don't do Windows, and I don't do Diff. Eq.
You're using 100 psi Air to fill a 5.6 CF bottle to 99 psi every 2 seconds.
This is about 175 cfm of 100 psi air.
Looking in my Crane Engineering Data booklet from 1976, 179CFM of 100 psig, 60 F air is equivalent to 1400 cfm of free air at 60 F and 14.7 psia.
Based on the table, I would suggest trialling 2", 2-1/2" and 3" pipe to see if any of them work to your satisfaction.
Not a pretty solution, but the best I could do in under 5 minutes.
08/29/2007 2:55 AM
Scan CR4 mechanical section. Ducon as I recall did give a conversion factor of free air to compressed inclusive other formulas. Maybe this may help.
Good Answers: 18
08/29/2007 9:00 AM
"Aside from using differential equations can anyone recommend any other possible means of doing this or perhaps suggest how I should use the above formula ?"
The problem you pose is why there is a need for such mathematical things as differential equations, although sufficiently accurate answers may be gotten otherwise.
A similar problem is the charging of a capacitor with a fixed voltage source through a resistor. The peak flow rate will occur when the tank to be filled is empty, and decreases from that point on. Calculating the flow rate for "free air discharge" will give you an idea of resistance to the highest air flow rate. Thereafter, the flow rate decreases exponentially.
The time constant of the system is determined by the resistance of flow in the piping and the capacity of the tank to be filled. The tank will be essentially at full pressure after 5 time constants. It will be approximately at 63% of full pressure at one time constant.
Given what you already know, you may be able to figure out the rest. Keeping the units straight is up to you.
P. S. A short treatise on Time Constant may be found on Wikipedia at http://en.wikipedia.org/wiki/Time_constant
Good Answers: 18
08/29/2007 11:52 AM
Here's a little help with my last post.
The equation which describes your system is Pt(t) = P(1 - e-t/RV), where Pt(t) is tank pressure at time t, P is manifold pressure, R is resistance of pipe of a given length and diameter to air flow, and V is volume of tank.
And the plotted curve (tau is RV) is:
This still doesn't give you the system time constant, but I hope you get the idea.
08/30/2007 10:22 AM
Thanks to all who contributed - I suprised myself and knuckled down with the Math and turned up some pleasing results (even if they look waaaay to basic for the amount of work input !!)
Here is the resulting curve (plotted against the flowrate from the vessel).
For anyone wishing to do similar I highly recommend the following works:
http://www.ijee.dit.ie/articles/999982/experime.htm
Good Answers: 19
08/31/2007 8:58 AM
Nice curve, about what I would guess would happen. I could not read the units on the chart though.
What size hose or pipe will you end up using for your tanks? How close is your number to my S.W.A.G.?
Anonymous Poster (2); Bill (2); FKIA (1); Ried (2); user-deleted-1105 (1); Windza (1)
