Previous in Forum: Marking ink application   Next in Forum: Nano Quartz
isobutane to n-butane
08/28/2007 8:29 AM
any idea how to convert isobutane to n-butane..deisobutanizer? really need to know more about this..
Re: isobutane to n-butane
08/28/2007 9:32 AM
Try Googling 'C4 Isomerisation Processes'!
Safety - Hazmat - PHA / HAZOP Facilitator Engineering Fields - Chemical Engineering - Principal Engineer Engineering Fields - Piping Design Engineering - Chemical Process Engineer
08/29/2007 4:54 PM
Try C4 Isomerization and you will have slightly better luck on the n-butane to isobutane process.
There are several catalysts that can do this for you in a column type reactor bed. The separation and recycle is the key to cleaning up your n-butane stream. UOP has a process that works pretty good:
http://www.uop.com/refining/1041.html
As to the iso to normal butane process, the separation is via distillation. The distillation column is commonly called a deisobutanizer.
If you need help with the design, there are lots of chemical engineers out there willing to do the work (shameless plug).
Stephan
Do what you will whilst harming none.
08/29/2007 5:09 PM
Converting iso to normal involves a patented process which consists essentially of contacting normal butane at temperatures less than 50 °C with a catalyst of fluoresulfuric acid and trifluoromethanesulfonic acid. I am not familiar with the specifics.
