Previous in Forum: Flow induced vibration problem in a cross flow tube bundle heat exchanger.   Next in Forum: Analysis of Hybrid Vehicles
Hot Reheat Pressure in Steam Engine Turbine
08/30/2007 1:47 PM
what are the main reasons that can cause hot reheat pressure to increase and LP bypass valve open in steam turbine 393 mw , the set point for reheat pressure is 43 bar , the LP by pass valve open at full load, and in diffrent loads the reheat pressure is alwyes higher than design value
Re: hot reheat pressure in steam turbine
08/31/2007 5:09 AM
Clean the condenser. PV=MRT, pressure equals temperature
Corn Stoves
08/31/2007 1:24 PM
dear sir
can you check up your governing system. at times if the ip control valve tries to close then the hrh pr rises. during that condition first the lpbp opens then if the pressure is not relieved the safety valve pops.
you have to give more details to find out more.
bye have a nice time.
pkmohapatra
pkmntpc
Register to Reply 2 comments
