Electrical and Chemical Anomaly
What we have Power Plant 4160V, Feeder 5kv. Teck. cables 500mcm. Parallel runs directly buried accept for 3m. Out of building and step-up transformer in 4" PVC. Conduit
Apr. length 100m. Transformer 4mva. 5kv. To 25kv. Pad mount.
Problem:
Transformer all ground copper wire, ground bus bar, copper and bras lugs, bras oil drain valve and grounding jumpers from transformer to the doors apr. 5' up were black tarnished like burned. Inside the switchgear main ground wire was black and showing sings of scaling,
The teck cable drain wires closest to the floor were tarnished and periodical tarnish towards teck connectors which are apr. 12" off floor? It is not heating effect it has to be chemical reaction.
Note:
Conduits at both locations show water apr. 12" from top and smelling like coal gasses
We did initial test 2 years ago injecting 1.25mw trough load banks and the plant has not bin running since.
Any ideas what might cause this and how one would go about to clean the tarnish off bus bar and copper wire? Any help would be greatly appreciated? Thanks
