Previous in Forum: Stress Definitions   Next in Forum: bolt torque
Pressure Switch for Pump Trips
08/31/2007 8:19 AM
Hi
Can somebody give me technical explanation for a low pressure trip - pressure switch application in a process pump header line. what should be the consideration for the set point value selection.
I wanted to install pressure switches(burden tube type) to a process pump output header line of having 3 to 4 Bar pressure. The pump should trip while the pressure falls below set point (eg 0.1Bar) and should not trip while starting(timer delay in the ciruit). I would like know how we can arrive a proper value for the set point.
Your advise will be highly apprecaited.
Thanks
Safety - Hazmat - PHA / HAZOP Facilitator Engineering Fields - Chemical Engineering - Principal Engineer Engineering Fields - Piping Design Engineering - Chemical Process Engineer
Re: Pressure Switch for pump trips
08/31/2007 11:08 AM
Usually, I use the low pressure on the pump discharge to indicate a problem downstream (like a line rupture or valve open that shouldn't be open in a particular step) and to keep the pump running on the pump curve. So, to answer your question as to a proper set point and time, you need to have a look at the pump curve for your pumps.
Follow the curve out to the right and have a look at the lowest pressure when the pump is running out on the curve (post a curve or pump model / impeller size and we can point it out). Take this pressure and provide an appropriate safety factor (I usually use about 50%, but that is for simple water distribution systems – it really depends on your system and how flat the pump curve looks).
Allow about 5 to 10 seconds for pump start and be sure you have a way for the operator to reset the system so the pumps can be started again (don't laugh, I had a PLC programmer forget this little requirement and we couldn't restart the pumps).
Stephan
Do what you will whilst harming none.
09/01/2007 12:22 AM
Dear Stephen
Thank you for the valuable information. I will look in to the pump details and let you know the characteristics. The pump is installed in diesel filtration unit.
Thanks
You might be interested in: Gas Pressure Regulators, Pressure Regulators
