olabisi olusola writes:
Please, I need your help on an automation issue. I am working to protect a very sensitive equipment against over and under frequency. It has to be done in such a way that when the frequency goes above or below a preset frequency, the equipment will automatically shutdown. Can you suggest a component that can do this?
Also in an automatic battery charging unit I am using LM324 as a comparator. When the battery is fully charged, the operational amplifier releases high voltage which will bias the transistor and the relay controlling the charging will switch off. I noticed that the relay keeps on switching on and off. What can be the reason?
