Previous in Forum: Questions   Next in Forum: Power and Signal Cable Separation
High Temperature for the excitation transformer
09/05/2007 5:47 AM
What makes the excitation transformer temperature to go high. Its rating is 11KV/415KV, I-21.5A, 50HZ, 410 KVA.Cooling - AN. The temperature rise is between 56-60 oC.At that temperature the Excitation field current is between 410-600. This is an excitation transformer for a hydro-plant gen.
Please give me the possible causes and measures, thnk you.
poy
Re: High Temperature for the excitation transformer
09/06/2007 12:40 AM
Please correct your question. All the figures in you question are inconsistant. For an answer one needs to know the name plate data of 1) Excitation Transformer i.e. Rated kVA, Volatge, Current, Phases. 2) Excitation Rectifier i.e. Rated Input Voltage (1 or 3) Phase, Output Voltage and Current.
MIQ
09/07/2007 9:10 AM
The voltage rating is 11kv/415V.
I- for current
3Phase.
poy
Good Answers: 61
09/06/2007 8:50 AM
If the heat is significantly higher in one location, you may have a loose connection or shorted winding turn. If the heat is generalized over the entire unit, the problem is likely related to environmental or operating conditions. If available, a thermal imager (infrared thermometer) will help pinpoint a localized problem. In a pinch I've used a zero lux camcorder (it has an infrared filter for extremely low light conditions).
If the temperature rise is not in a specific location, I would check the following:
1. If the transformer is in a protective enclosure, check the cooling louvers and filters (if any) for dirt or other obstruction.
2. Look for a buildup of dust or other grime on the windings. This will act as an insulator and prevent proper cooling of the windings.
3. Is the Excitation transformer overloaded (compare the actual current on all input phases with the nameplate rating)?
4. Is the ambient temperature higher than the nameplate rating?
5. What has changed since the unit was operating at normal temperature?
09/06/2007 6:15 PM
Above 410, you have exceeded the device's rating of 410kVA. The average is certain to be above 410 kVA.
The purpose of a system, is what it does.
Register to Reply 4 comments
hioptemp (1); MIQ (1); olivinak (1); pwr2thepeople (1)
