Previous in Forum: 741 Contest   Next in Forum: Slipring Motor
11 comments
A Christmas Present
12/24/2017 4:19 PM
I found this little puzzle on the wall of the men's room in the EE building at Purdue 50 years ago. As I recollect it took me most of the day to solve it.
A ladder of 1 ohm resistors extending to infinity. What is the resistance R looking into the ladder? Hint: while you may be rational, the answer is not.
Merry Christmas!
Re: A Christmas Present
12/24/2017 5:31 PM
The resistance R is (1 + 1) + (1 ohm in parallel with R) .
R=2 + R / (1+R)
R-2 = R/(1+R)
R2-R+2 = R
R2-2R+2=0
12/24/2017 5:47 PM
R=1+sqrt(3).
12/24/2017 5:58 PM
Spot On. Reduces to R²-2R-2=0, and we all know how to solve that. Looking forward to many more discussions in the New Year!
Good Answers: 120
12/25/2017 10:06 AM
not correct, the two input resistors do not reduce.
Per Ardua Ad Astra
12/30/2017 11:10 AM
So that would make the answer 1+ SQRT(2)
12/30/2017 12:17 PM
Randall, the +2 should be -2. And the answer is 1+sqrt (3).
12/25/2017 1:14 PM
I would be looking on the wall for 867-5309, for a good time call.
Good Answers: 116
12/26/2017 11:48 AM
It is a symmetrical T attenuator chain with each section made up of 5 resistors of 1 ohm and a source/load resistance of 2√2 ohms = 2.82843... ohms. An infinite chain will be 2.8243 ohms input
As a check, if you terminate one section of 5 resistors of one ohm with 2.83 ohm, you have (1 + 1 + 2.83) // 1 ohm = (4.83*1)/(4.83 + 1) = 0.8285 ohm: then +1 + 1 = 2.83 ohms input resistance.
Good Answers: 116
12/26/2017 12:58 PM
Urgh. Complete goof by me.
The repeating "symmetric T" is 4 of 0.5 ohm series with a shunt of 1 ohm, having terminal resistance of √3 = 1.732 ohms, add 1 ohm at the input end gives 2.732 ohms.
But Richter also suffered from the Christmas surfeit, his formula should end
R2 -2R -2 =0, so 7.464 - 5.464-2 =0 when R = 2.732..
12/26/2017 1:18 PM
My shaky memory of maths means I can't put it in a neat formula - but by inspection the first parallel resistor is in parallel with an infinite series of 2 ohm resistors all in parallel - which if taken to the limit will get to as near zero as you like. This leaves 2 x 1 ohm resistors in series.
I plonk for 2 ohms.
12/27/2017 4:32 PM
<...on the wall of the men's room in the EE building at...>
On the wall of the men's room in the Mechanical Engineering building at Exeter adjacent to the "confectionery dispenser" was the expression, "Not to be used above 400rpm"!
Register to Reply 11 comments
67model (2); aurizon (1); horace40 (1); PWSlack (1); Randall (1); Rixter (2); SSCpal (2); tonyhemet (1)
