Previous in Forum: multiple drive   Next in Forum: solar photovoltaic panels
lightning strikes
09/06/2007 9:34 AM
Hi
One good friend of mine got struck by lightning, lukily he survived, his wife, in the house, survived too, but not the house. Hence, he got interested on the subject. One surprising thing was we think our tires insulate our cars from grounding a lightning, apparently not, it would be the metal roof. And, to my dismay, sitting in a convertible would be almost equivalent to sitting outside ...
I would like some input on that, and would a metal roof be the only good protection against lightning ? Hydro and electrical distribution should protect.
24000 p / annum dead, 240000 p/annum survive ... on the planet ... food for thought.
Engineering Fields - Electrical Engineering - New Member United States - Member - New Member
Re: lightning strikes
09/06/2007 10:51 AM
There was a very thorough and informative thread just a short time ago:
http://cr4.globalspec.com/thread/10231
Tdesmit
09/06/2007 2:41 PM
Looked at the comment,
Faraday, likely, but the AC theory makes sence too. could be both, but ! Environment could be another factor, and, as discussed in earlier thread on magnetic fields effect on human body, something came up two month ago concerning powerlines. The hydro bill did not come alone, a warning came with it and i will investigate further on the warning passing under a powerline affecting us. Too early to deapen the discussion, brain storming with my friends "engineers" should occur first.
Back to the drawing board.
YC
Good Answers: 143
09/06/2007 11:44 AM
I think I can give you some definite answers.
No, the tires don't do a thing. Friends of my were sitting at a traffic light when their minivan was hit. Blew all four tires and welded the wheel bearings.
A metal vehicle is obviously some help but is not perfect. The record holder for being hit by lightning, US Park Ranger Roy Sullivan, was hit twice while in a vehicle.
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
09/06/2007 6:53 PM
Tires do not insulate the car from the lighning. The metal body acts as a Farady cage that directs the current around the occupants. You will be safe inside the car as long as you are not in contact with the exterior or there is no conductive path from you to the exterior.
One of the foremost lightning researchers today is Ron Holle. I heard him make a presentation in Tulsa a long time ago when he worked at the National Severe Storms Laboratory in Norman, Oklahoma. I believe he is now working in Arizona. He might be interested in hearing your friend's story.
A metal roof might provide some protection from lightning, but the best protection is to give the lightning an easy path to ground that takes it away from your household wiring. That's the principle behind Benjamin Franklin's lightning rod. If you want or need a more high-tech approach to lightning protection, PolyPhaser Corporation offers an assortment of products and some literature. You can check them out at www.polyphaser.com, or http://www.globalspec.com/Supplier/Profile/PolyPhaser.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Register to Reply 4 comments
3Doug (1); tdesmit (1); TVP45 (1); yellowcat (1)
You might be interested in: Lightning Protection Systems, Roof Curbs
