Previous in Forum: AC generator   Next in Forum: toyota 5A-FE engine wiring diagram
back up system
09/06/2007 7:59 PM
i want industrial back up system during power outage how can i back areas that are affected by power failer on regular basis? which generators are recommended for backing up metro areas.
Re: back up system
09/07/2007 4:24 AM
The island of Jersey has two huge Maybach diesel engines and a hot-standby steam turbine installed in its only power station in St. Helier. Normally the island receives cheap nuclear-generated electricity via a high-voltage undersea cable direct from France.
India - Member - New Member
Re: back up system
09/13/2007 6:11 AM
1. Peak Lopping Plant
It is mostly used where high loads occcurs at certain known times for a particular plant/process functions .
2. Uniterruptible Power Supplies
Rotrary or Static Equipment is available
3 . No Break Generating Sets
It consist of a large Flywheel rotating with electric generator and a clutch isolating the engine .When the power fails the system is automaticaaly started with the engagement of the clutch.
4 . Mobile Generating Sets.
Usfeul where sets are reuired in different locations
