Good morning,
I work for a bridge expansion company. i have been searching for a while now for some sort of Santoprene sheet or rubber sheet that will be able to bond together
two rubber expansion joints . the parts are made of Santoprene and they are cut at a 45 degree
and vulcanized together. but it is taking to long to process. that is why i am searching for a way to bond the parts without retouching later on. I believe there
is a thin sheet of rubber that by using a heat gun i could bond these two parts together in less time then vulcanizing.
My question is can you point me to the wright direction in were i could find
this material or some sort of bonding agent for purchase. i would appreciate any help.
Thank you.
Emilio P. Santos
Sample/ Literature dept.
Watson Bowman Acme Corp
95 pine view drive
Amherst N.Y. 14228
1-716-817-5438 ext.5438
