Previous in Forum: Refrigeration   Next in Forum: Brazing using BCuP5 filler
Separation Efficiency of 3-Phase Oil & Gas Separator
09/07/2007 8:59 PM
We have a new 3-Phase (oil & gas) separator, designed in accordance with API 12J and ASME BPVC Section VIII, Div. 1. Now, the separator is under experimental and test operations. We need to evaluate the separation efficiency for both liquid/liquid and gas/liquid.
a. What are the recommended equations to be used?
b. Is there any API (or any other code) supporting these equations?
Engineering Fields - Piping Design Engineering - New Member Engineering Fields - Petroleum Engineering - New Member Venezuela - Member - New Member APIX Pilot Plant Design Project - Member - New Member
Location: Valera -TRU, Western-Venezuela, South America
Re: Separation Efficiency of 3-Phase Oil & Gas Separator
12/11/2007 10:32 AM
Hi Sir Abdel Halim Cairo Refinery: I am writing from Venezuela-South America, please see my profile in Piping Design& Petroleum Engineering Groups in CR4.
Recently I saw your inquiry on 09-07-2007 about " Evaluation of Separation Efficiency of 3-phase water-oil-gas separator". None answered but (never is too late) I think I can help you. I like to send you some guides of the Processes Manual ( of course when you send me your e-mail address) and others technical papers about it.
The equations governing the traditional design gas-liquid or liquid-liquid separation are the Stokes´s Law, Gravitational Law and Momentum. You know that!
Additionally, the parameters to consider are:
1. Separator Type (vertical, horizontal)
2. Flow rates
3. Properties of fluids including specific gravities, viscosities, surface tension, droplet sizes
4. Geometric configuration
5. Internal devices ( flow distributors, deviators, baffles, demisters).
6. P y T @ operations conditions
Best regards
Joe
12/12/2007 2:31 AM
Dear Joe
Thank you very much for your interesting. Can you please send me the Process Manual on my e-mail : abujalala2005@yahoo.com , with my best regards.
Register to Reply 2 comments
