Previous in Forum: Separation Efficiency of 3-Phase Oil & Gas Separator   Next in Forum: Correlation btwn. fuel consumption l/100km and CO^2 emission g/km
Engineering Fields - Mechanical Engineering - I am here to help!!
Brazing using BCuP5 filler
09/08/2007 3:47 AM
I am having ASM handbook on 'Welding & Brazing' Volume 6, 8th edition. I am refering the handbook to know more about brazing. Currently we are brazing an ETP grade Copper strip (2.5 thick) to a spring steel strip (thk 2mm) plated with 60-70 microns of copper using BAg-1 series filler metal. Since this filler alloy is costly & production is huge, we are thinking of replacing it with BCuP-5 filler metal (after referring the handbook). As I have already mentioned the steel strip is already plated with copper, so basically the brazing is of ETP copper to pure copper. As you know BCuP series filler metal is not good for steel materials as it forms Iron Phosphide (which is brittle). But, there are some examples in the handbook, where Copper plating of 3 to 5 microns is used, so that BCuP5 filler can be used for brazing (but the plating is done on bronze). Still, I just want to confirm, whether this will work. Pls advice.
Re: Brazing using BCuP5 filler
09/10/2007 10:06 AM
If you're torch brazing you have to be careful about burning off the copper...
I wasn't here that day.
09/10/2007 7:43 PM
I think, you can do this by using a small flamespray torch, commonly known as a puddle torch and a Cu-P5 powder very easily by using a reducing flame on the torch as the Copper Phos has a very low melting point it works really fast and easy. We have been able to repair holes in copper tubes with water in them easily with this Process.
09/10/2007 11:18 PM
If you go thru my question, my problem is not heating process. I need help on my material. We are doing flame brazing & soon will be switching over to Induction brazing.
Will the copper plating of 60-70 micron work on Spring steel, while using BCuP5 filler foil.
Register to Reply 3 comments
MechTech Gid (1); pc (1); vishmayor (1)
