Previous in Forum: VFD Altivar Hoist Problem   Next in Forum: Looking for a Development Platform to be Used on Windows
8 comments
IEC Cable Sizing
02/06/2018 9:55 AM
NFPA 70 430.22(A) Branch-circuit conductors for a single motor, continuous duty, shall have an ampacity of not less than 125% of the motor’s full load current.So, Cable Ampacity > 1.25 x FLA x derating factors.
As far as I searched there is no 1.25 multiplier in IEC, Cable Ampacity > FLA x derating factors.
Is the above correct?, or there are some multiplier/margins for cable sizing as in the current project we are going use the cables which are manufactured according to IEC.
Pathfinder Tags: IEC Cable Sizing
Re: IEC Cable Sizing
02/06/2018 10:28 AM
I would also be curious to know the answer to this.
Please let me know
Thanks
02/06/2018 10:37 AM
Good Answers: 125
02/06/2018 1:45 PM
My experience is that IEC is much more "relaxed" than NFPA 70 (as are many regulations in Europe compared with NFPA).
We Americans like the overkill safety factor.
Good Answers: 181
02/06/2018 3:56 PM
“IEC is much more relaxed.”
It depends on where you are under the IEC banner. BS7671 is quite strict on earthing (grounding) requiring earth loop impedance testing and documentation, testing that the NEC doesn’t require.
New Zealand - Member - Kiwi
Good Answers: 29
02/06/2018 5:06 PM
Down here in NZ we are mostly IEC.
We wouldn't be required here to oversize a motor feeder by 125%. The feeder would be dimensioned based on motor FLA and feeder length where appropriate. The cables that are used here are broadly the same csa vs amapcity as in NEC-land too.
Another key difference is in the circuit breakers. For a motor circuit, the preferred circuit breaker (for smaller motors which can be protected with miniature circuit breakers) is a D-Curve which trips magnetically at 5x - 10x rated current and so can buck motor starting currents better than the C-Curve which is used for most other loads.
paulusgnome
02/06/2018 5:29 PM
If in doubt, consult a qualified local Electrician. To do otherwise invites the risk of a measure of unpopularity with the facility's fire insurance cover provider.
Hobbies - Musician - New Member Hobbies - Car Customizing - New Member Hobbies - Target Shooting - New Member Engineering Fields - Power Engineering - New Member
02/07/2018 6:35 AM
Talk to the AHJ, as in authority having jurisdiction. When it comes down to it, their opinion is the one that matters. If you are in the US, you will most likely fall under the NFPA guidelines, I would hazard to guess Canada (and maybe Mexico?) would be similar. Outside of the Americas, you will most likely will fall under IEC purview. I can tell you, opinions from the internet are worth exactly what you paid for them. Get in touch with the local authorities. They can guide you better than we can.
Good Answers: 42
02/08/2018 3:15 AM
Let's take an induction motor of 100 hp/460 V [122 A and 122*1.25=152 A]
and 75 kW 400 V [142 A rated].
Comparing NEC Table B.310.15(B)(2)(8) with IEC60364-5-52 Table A.52-5 (52-C4)
NEC 2 AWG[33.63 mm^2]161 A IEC 35 mm^2 144 A
The calculation theory are close: Nehrer&MacGrath vis-a-vis of IEC 60287.
NEC exudes the fragrance of democracy :less theory more practical.
So, the IEC is close to theoretical results while the NEC it is more practical.
Julius
Register to Reply 8 comments
7anoter4 (1); IanR (1); lyn (1); Paulusgnome (1); PWSlack (1); scott165 (1); TonyS (1); WJMFIRE (1)
