Previous in Forum: Boiler Interview Questions and Answers Part 1   Next in Forum: Principle Stresses for Thick Walled Cylinder
Resetting Error Code in VRV Daikin Air Conditioner
02/09/2018 11:20 AM
We have the DAIKIN VRV Cooling system which stopped working and display an error U O3 Blinking. How can I reset this error or what is the cause of problem?
Re: RESETING ERROR CODE IN VRV DAIKIN AIRCONDITION
02/09/2018 11:27 AM
02/09/2018 1:11 PM
I take it to mean there is a low refrigerant problem and a wiring issue or circuit interruption, which could just be the low pressure switch tripped....but I'm just guessing...If you have a ref leak, it should be located and repaired...call a pro
02/09/2018 2:19 PM
Sounds like another and appropriate ESO condition.
02/09/2018 10:40 PM
Solar Eagle : You didn't go to Google too, did you ?
02/10/2018 3:13 AM
I went to google and found error U3 means Check operation not executed after completion of installation or after replacement of the main PCB board. However, in this case the AC was working without any problem for the past three years, it stopped working with U3 error in both remote and outdoor main PCB Board. I think that could not be because of check operation execution.
Re: Resetting Error Code in VRV Daikin Air Conditioner
02/12/2018 7:05 AM
Please tell the forum why it proved impossible to resolve this problem with the equipment manufacturer over the telephone, including gaining access to the User Manual for the equipment?
That would be worth reading...
Register to Reply 6 comments
dmtonyole (1); PWSlack (1); redfred (1); SolarEagle (2); tonyhemet (1)
