Previous in Forum: French Drains   Next in Forum: Is it Load Bearing?
8 comments
Check for Overturning
03/08/2018 2:00 AM
Hello house,
Pls how do i check for overturning with the values given on the table below. The values were gotten from the analysis and design of a 15m Roof top square tower.
MAXIMUM FOUNDATION FORCES:
FORCE
LOAD CASE
MAGNITUDE (kN)
COMPRESSION 6 162
UPLIFT 6 152
LONGITUDINAL SHEAR 6 6
TRANSVERSE SHEAR 6 6
Re: Check for Overturning
03/08/2018 9:33 AM
Does the tower look like this?
http://www.va3cco.com/towersheight.pdf
03/08/2018 12:49 PM
03/09/2018 11:48 AM
it is a 4 legged stand alone tower. And does not have such type of Antenna
03/09/2018 12:07 PM
This means all 4 legs can have different loads, some uplift.
Lehman57
03/13/2018 4:47 AM
"A picture is worth a thousand words" - Anonymous Poster #0
Hobbies - CNC - New Member
03/08/2018 10:52 AM
With the huge amount of information given,
I think it may look like this!?!?!?!
03/08/2018 11:02 PM
Yep, tell us more--lots more. How much horizontal load? Direction(s) or load(s). Height of load application? Vertical loads? Amount of deflection for use in getting P-Delta moment? Width of base? Etc.
Lehman57
03/09/2018 1:59 PM
- General Purpose(s)/use(s), service life, salient detail(s), etc.,?...
- Location, in what jurisdiction, under what prevailing Codes, Regulations, Rules,?...
- Tower type, consisting of what structural, material(s), construction characterisics?...
- Overturning, in response to what loading, wind, seismic, corrosion, other, condition(s), etc.?...
- Resisting, with what type(s) of foundation(s), tie-down(s), ballast, etc.?...
Register to Reply 8 comments
Johnson David (1); Lehman57 (2); MR. Guest (1); Original_Macgyver (1); PWSlack (2); SolarEagle (1)
