Previous in Forum: Wanted: Capacitors   Next in Forum: High-Temperature Cable Connector
Generating PCB Excitation Pulses Without a Generator
09/10/2007 11:50 PM
dear readers,
i had bought a module SRM400 recently. i have difficulty on searching the materials on the net regarding on how to generate excitation pulses to the circuit board without the waveform generator.is there a way?
thank you
--<@nOiTaNiMrEtEd@>--is the Way
Re: Generating PCB Excitation Pulses Without a Generator
09/12/2007 3:43 AM
Google for "555 timer" and you`ll find the cheapest, simpliest methods to trigger your SRM. Regards Uwe
The sum of intelligence on earth is a constant. And the population grows and grows and .....
09/12/2007 3:55 AM
thank you very much for the replied.however,is there anyway to replace it without using software applications?because i know for 555 timer,there is an involvement of software.only hardware will do..
thank you very much
09/12/2007 4:07 AM
There is no involvement for software - all you need is a datasheet (from national semiconductors, texas instruments or others) in which you will find a nomogram which shows you how to select the frequency-determining components (R and C) and how to connect the 555. Good luck !
09/18/2007 4:13 AM
do i have to use a specific 555 timer?it is because there are many models out there.how about timer such as LMC555?what's the difference?
thank you
09/20/2007 6:18 AM
You`ll find the differences looking at the datasheet. Some 555 are CMOS-types, some are bipolar types. The CMOS-versions have a lower static current consumption and make lower dynamic current pulses while switching and so they are a little bit better but in your application you can use "everything which has eight legs" ..... ;-)
09/20/2007 8:29 PM
it said in the datasheet,CMOS version use lower power too.then i will choose CMOS version.thank you very much for your help
Register to Reply 6 comments
