Previous in Forum: Hardening process   Next in Forum: Sprocket, Chain and Center Distance
Shell Tube Heat Exchanger
09/11/2007 4:21 AM
dear friends
I am looking for chemical solution suitable for cleaning shell tube heat exchanger where material of sheets is sea water resistant brass and tube material is copper nickel.
Re: shell tube heat exchanger
09/11/2007 7:03 AM
Sorry, not my area of expertise but is that hesham from Hesham as in place with large installation visible from M6?
Wish I was here more often.
Re: Shell Tube Heat Exchanger
09/12/2007 5:19 AM
For such purpuses we use Sulfamic acid solution or BS12. We have used it in the past for desalination units or Shell tube HE cooler using sea water. It requires a closed loop system connected to tube side, a pump and a container. During cleaning you need to verify the PH.
Kamel
Good Answers: 19
09/12/2007 10:23 AM
Test pH frequently during cleaning, follow the suppliers recommendations, and flush system thoroughly when finished and before putting system in service. Take your time and be careful.
09/12/2007 11:10 AM
Contact Nalfleet or Unitor for chemical cleaning agents in heat exchangers, the agents will be environmentally friendly too and they'll sell you the brushes to punch the tubes.
Register to Reply 4 comments
Anonymous Poster (2); Ried (1); Wrenched (1)
