Previous in Forum: Shell Tube Heat Exchanger   Next in Forum: Temperature and Weld-Joint Efficiency
Sprocket, Chain and Center Distance
09/11/2007 7:35 AM
Hi Everybody,
I am curious to know if the there would be a drop in the amount of torque, if sprocket and chain wear out, provided the centre distance is increased to compensate the wear and maintaining the slackness. Also, what are the other reasons for drop in torque, apart from piston/bore wear, clutch plates wear and the wheel condition.
Thanks in advance
Mr. Idiotalways.
Good Answers: 143
Re: Sprocket, Chain and the centre distance
09/11/2007 7:47 AM
Hello,
I don't know your application, chain or sprocket type, etc, but my experience in medium-size servo drives has been that torque does not vary greatly with normal ranges of slackness unless you're running it backwards and really loose. However, it is normal to put a "droop" spec on such drives and to have a tensioner arrangement. Just how worn are these parts?
Re: Sprocket, Chain and Center Distance
09/12/2007 8:09 AM
Looking at the profile of worn sprockets (running Reynolds type roller chain I assume) I'd say the torque could increase or decrease (by a pretty small amount) depending on whether this was step-up or step-down. The teeth wear so that the chain rides radially outward. Varying centre distance hasn't the slightest effect, unless you tension the chain massively trying to keep it lower on the teeth. It wouldn't have much of a life in that condition.
Wish I was here more often.
09/12/2007 12:17 PM
< if the there would be a drop in the amount of torque, if sprocket and chain wear out, provided the centre distance is increased to compensate the wear and maintaining the slackness>
No isthe answer.
<what are the other reasons for drop in torque, apart from piston/bore wear, clutch plates wear and the wheel condition.>
None other.
09/12/2007 1:35 PM
If all the things you mentioned are worn, there is a real good chance your wheel bearing are shot too. Also carburetors wear out/get dirty and need adjustment/cleaning. Both of these items can reduce effective torque at the rear wheel.
MUKULMAHANT (1); silvCrow (1); TVP45 (1); Wrenched (1)
