Previous in Forum: Grab Your Energy Calculators   Next in Forum: Match the Drug to the Warning Label
Good Answers: 11
Wanted: Low-Power Flexible Heater
09/11/2007 10:18 AM
All,
I'm looking for a lower power (e.g 10w or less) low voltage (6-12vDC) flexible heating element. A flat heater encapsulated in rubber or other protective material would be good. Able to take near constant motion is necessary. Max temperature won't exceed 120F, so the materials set can be tailored to rough duty rather than high temperature.
I've tried Minco and other suppliers of heaters for lab equipment with no luck. Any suggestions?
Thanks,
Eric
Re: Wanted: Low-Power Flexible Heater
09/11/2007 3:11 PM
How about the heaters in snowmobile handgrips?
Check out Dennis Kirk or Shadetree catalogs.
09/12/2007 1:20 AM
How about the de-freezing heater of a larger fridge?
Aged man is not old man...
09/12/2007 2:38 AM
The main reason nobody will make that for you is due to the low resistance. They should have explained that to you, the lower the resistance the more difficult it becomes to obtain a very fine wire size.
Try using a different/higher rated element in regards to your voltage applied or maybe a stepup transformer from your dc power supply. It's costly but the only way to do it.
Try speaking to one of my suppliers Mr KT lee at Kaneta on kt@kaneta.com, maybe he could help you or recommend someone in the east?
Good luck
Ryan Sinnema. Q.B.E
Darton Suppliers
South Africa
Good Answers: 54
09/12/2007 3:05 AM
I've successfully used short lengths of thin copper, SILICONE sheathed cable with a low voltage, constant current source to make small heaters. Jeff
If there's something you don't understand...Then a wizard did it. As heard on "The Simpsons".
Good Answers: 94
09/12/2007 6:45 AM
We use custom flexible heaters from Holroyd to de-mist optics in cooled cameras. They are rated at 2W using 5V.
09/12/2007 9:41 AM
Have you tried heat trace cable they wrap around water pipes to keep them from freezing?
Register to Reply 6 comments
Anonymous Poster (3); ffej (1); Nigh (1); Qqberci (1)
