Previous in Forum: Roof Cooling   Next in Forum: Canonical Basis Vector and Some Other Issues
11 comments
CAN Bus
04/18/2018 1:41 AM
Hi. Need help here. I'm quite confused here about module and ECU.Under BCM, we should add ECU or not? Example, lighting ECU, Door ECU,etc.. Or, we already control all of that through BCM and just need to use driver only?
Re: CAN Bus
04/18/2018 9:42 AM
ECU? BCU?
Re: CAN Bus
04/18/2018 9:55 AM
Re: CAN Bus
04/18/2018 11:51 AM
. . . like ECU is an environmental control unit in a submersible. If you are driving a car, then it is probably an engine control unit, but we don't have enough information to help this poster.
Good Answers: 445
Re: CAN Bus
04/18/2018 10:42 AM
Your confusion cannot be solved here without much more information. Are you a mechanic, manufacturer, hobbyist, etc. The exact module(s) that you "add" will depend upon the existing network architecture of the vehicle that you are working on.
Depending upon the exact make, model, and year, you will find the ECU (Engine Control Unit) communicates with various function BCMs (Body Control Modules) distributed throughout the vehicle via the CAN (Controller Area Network). All of these devices are well defined and instructions for programming and interfacing with them are easily discoverable via your favorite search engine.
Re: CAN Bus
04/18/2018 1:08 PM
First, you should learn the technical meaning of all the words and initials you have used with no idea of what they mean, are, or do.
Module | Define Module at Dictionary.com
BCM - Wikipedia
You can define all the rest.
Get a proper definition of all the terms you have used.
Re: CAN Bus
04/19/2018 2:49 AM
...which is all NBG, really.
Re: CAN Bus
04/19/2018 3:32 AM
Already got my answer.. Thanks.. but you guys will see a lot of my questions regarding CAN bus at CR4.. Still learning here.. hehe
Re: CAN Bus
04/19/2018 6:26 AM
The repeated use of undefined acronyms will prove distressing to all involved.
<...guys...>
Also, not every reader here is male.
Ha, blinkin' ha.
Re: CAN Bus
04/19/2018 9:13 PM
LOL..I'm just a girl stuck in this CAN bus topic.
Re: CAN Bus
04/20/2018 12:33 AM
Is independent research, like Google, not something that you want to do?
Re: CAN Bus
04/20/2018 1:11 AM
Of course I did.And, when I discussed what I understand with my friends. every single of us had difference opinion .. we are not from engineering background and never know that vehicle using CAN bus.
Register to Reply 11 comments
Anonymous Poster (1); Brave Sir Robin (1); Kayya1993 (3); lyn (2); PWSlack (2); RAMConsult (1); SolarEagle (1)
