Previous in Forum: Water Temperature Under Vacuum?   Next in Forum: Eductor & venturi design resources?
Test Bench Needed for Pumps, Compressors and Governors - Please Suggest
09/13/2007 4:16 AM
Please can any one of us recommend reliable Test benches for the following:
1. Engine Governors
2. Diesel Fuel injection pumps of between 4 to 12 cylinders(Caterpillar engines)
3. Two-stage Reciprocating air compressor
4. 5-stage Centrifugal crude oil transfer pump.
All these will be used in a maintenance workshop for tests and repairs in Nigeria.
Good Answers: 58
Re: Test Bench Needed for Pumps, Compressors and Governors - Please Suggest
09/14/2007 3:54 AM
You have to be more specific, there is no "test bench" that I can imagine that is of any use for a crude transfer pump, unless you mean only a pressure test to see if the casing or seal leak statically.
For governors, injectors and fuel pumps contact the OEM.
09/14/2007 10:02 AM
Test bench that is capable of comparing design condition with condition after repais/overhaul to know if all parameters are within operating envelope at various speed and load bands.
09/14/2007 4:39 AM
test bench for diesel fuel injection pumps check hartridge.com
09/14/2007 10:23 AM
For#1&#2 ask http://www.adiesel.com/aboutus.html
For #3&#4 Merely study operating/maintenance Logs to keep a tab for preventive Maintenance.
If you want a training setup--ask your suppliers for Teaching Aids. And get Smallest model machines from them to teach principles to trainees .
05/23/2008 4:48 AM
Have you purased the test bench for Diesel fuel injection pumps ?
It is very vast line , you need to have reputed test bench New or if used
it has to be audit one to give you axact reading as recommended by eng manufacturer.
You need to have servised tools to handle dismentle and re assemble pumps
in proper way.
Anonymous Poster (2); MUKULMAHANT (1); sdimkpa (1); The Prof (1)
