Previous in Forum: Do We Still Need Discrete Logic Integrated Circuits?   Next in Forum: Designing Safer Digital Circuits for Interfacing and Driving Signals
2 Conductor or 4 Conductor Wire CAN Bus
04/24/2018 2:16 AM
Hello,guys. Can someone explain this to me? I got confused between this two conductor of wire..typical CAN bus only consists of two wire.
1.Where and when we used the 4 wire?
2.CAN-PWR & CAN-GND are same with supply power & GND?
3.If I just pass the CAN-GND, it will effect my CAN-bus network in vehicle?
Re: 2 conductor or 4 conductor wire CAN bus
04/24/2018 3:02 AM
A1) The forum is not able to see what the <...we...> used, nor why it did so.
A2) CAN-bus is covered by ISO 11898.
A3) -
Re: 2 Conductor or 4 Conductor Wire CAN Bus
04/24/2018 1:50 PM
CAN bus is kind of like ethernet. The devices hanging on the bus talk when they can. The four wires are power, ground, and a balanced line, i.e., when one signal goes high, the other goes low and vice-versa.
"...several de facto standards for mechanical implementation have emerged, the most common being the 9-pin D-sub type male connector with the following pin-out:
  • pin 2: CAN-Low (CAN−)
  • pin 3: GND (Ground)
  • pin 7: CAN-High (CAN+)
  • pin 9: CAN V+ (Power)"
https://en.wikipedia.org/wiki/CAN_bus
Here is an introduction to CAN bus that might be helpful...
https://www.csselectronics.com/screen/page/simple-intro-to-can-bus/language/en
04/25/2018 12:08 AM
Low power devices like some sensors can use CAN power. Higher power devices - ECU or motors, etc have their own power supply and power their end of the bus.
Madness is all in the mind
03/19/2019 11:35 PM
CR4 Admin: Spam: This post was deleted because it contained advertising outside the Commercial Space forum. Please review Section 14 of the Site FAQ about advertising.
GM1964 (1); minion (1); PWSlack (1); Rixter (1)
