Previous in Forum: Phase Angle   Next in Forum: Induction Motor Bearing Failure and the Cause?
Grounded Field Winding
04/30/2018 10:14 AM
dear all
I know the first ground fault in the field winding is signalizing only,because a single
earthing in the field winding is not immediately damaging,but why the
protection wait to second ground fault to trip the generator why not trip in the first
ground fault.and what should be do if the signal (field grounding) appear
thanks
Pathfinder Tags: field winding
Re: Grounded Field Winding
04/30/2018 10:35 AM
Well, that would depend upon the contents of the detailed electrical design documents with regard to any neutral connection, which documentation cannot be seen from here.
If there were no neutral to <...ground...> connection, then the first fault would not cause damage, though it might prove inconvenient, embarrassing, uncomfortable, or some combination of them. A guess might suggest that having two parts of the <...field winding...> both connected to <...ground...> would introduce heavy circulating currents through those connections and the <...field winding...> that might damage things considerably, and it would be better to trip on the fault than for the damaging situation to continue for longer than the trip operating time.
Good Answers: 445
04/30/2018 8:44 PM
When I was an engineering student on a co-op assignment at a major generating station, I posed the same question to my manager. His answer was simple and perfectly logically, "Continuity of service". Rather than an immediate trip which would suddenly remove 600MW of generation from service, the operators were alerted to the ground fault, and could perform an orderly shutdown of the unit without affecting any customers.
My followup question was obvious, "what about a second ground fault?". His answer, "It's unlikely that a second fault will occur before we take the unit out of service, but if it does, we're already prepared for the trip."
05/01/2018 11:23 AM
One ground fault may or may not let out the magic smoke eventually depending on where the fault occurs.
Two ground faults are guaranteed to let out the magic smoke in the very near future.
Register to Reply 3 comments
Jpfalt (1); PWSlack (1); RAMConsult (1)
