Previous in Forum: Sick house syndrome?   Next in Forum: thermoluminescent light
20 comments
Salt water able to burn??
09/13/2007 12:54 PM
Hello all:
Has anyone heard the report of a guy being able to cause salt water to burn (combust) using essencially radio waves??
It would be interested in hearing your thoughts on the subject.
Good Answers: 15
Re: Salt water able to burn??
09/13/2007 2:57 PM
http://onemansblog.com/2007/05/31/machine-literally-burns-saltwater-and-cures-cancer/
downhill slide to 112 (damn memor.)
Good Answers: 18
09/14/2007 2:54 PM
following this blog, everyone seems interested in the H2 generation, etc. Whatever happened to the cure for cancer?
09/17/2007 10:55 AM
You have made a notable observation, however this is a forum for engineers to exchange ideas and discussions; we are not physicians.
With that being said, a lot of good would come from a effiecient, low cost hygrogen producing technique. It could run all the cancer curing devices around the world.
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
09/13/2007 3:02 PM
I wonder..... Would Schrödinger's cat play with a ball of string theory?
09/13/2007 11:52 PM
I've seen the video, he pumps a huge amount of radio freq energy in and gets a small plasma on top. Should get the free energy people going.
Of course you can get water to burn, just break it down into Hydrogen and Oxygen, then recombine and burn it. Only trouble is, it takes more energy to break it apart than you get back (when you take into account the losses). Jeff
09/14/2007 1:37 AM
What happened to the salt?
"The more I learn, the more I know the less I've learnt"
09/14/2007 6:25 AM
Here I am producing Hydrogen gas in salt water. The byproduct is sodium hypochlorite or chlorine bleach.
1.1 billion people do not have safe drinking water
09/14/2007 7:12 AM
That's cool!!!
Just noticed something to the right of the bucket... Is that a CRACK on the floor?
09/14/2007 7:24 AM
Yep, that is the front porch of my grandfathers old farm house. I use the front room and porch for my shop and lab. Five gallons of wter, 1 pound table salt, some dc current and you get enough sodium hypochlorite to purify 25,000 gallons of water more or less.
09/14/2007 7:44 AM
"Five gallons of water, 1 pound table salt"
Can you do the same with sea water? I have a "lot" here to offer.
09/14/2007 9:13 AM
Sure, It will work with seawater. It is being done in other parts of the world
United States - Member - New Member Engineering Fields - Mechanical Engineering - New Member Popular Science - Weaponology - New Member Hobbies - Target Shooting - New Member Safety - ESD - New Member Technical Fields - Education - New Member
09/14/2007 9:28 AM
For such a little island you guys are spread far and wide. I work with a guy from Yap. Small world.
-A-
question everything
09/14/2007 9:47 AM
Here is something I copied off of the net
On-site generation of sodium hypochlorite as a means to deliver chlorine has been practiced for years on oil and gas production platforms worldwide. It provides a much safer disinfection mechanism than handling chlorine gas or biocides, and it is more proven than UV or ozone in use upstream of seawater filtration equipment.
Seawater can be used as the source of the chlorine ion needed to produce hypochlorite through electrolysis. Normal seawater has a chlorine ion concentration of 19000 - 20000 mg/l. DC current is passed through seawater in a cell to generate hypochlorite through a series of oxidation, hydrolysis and reduction reactions. The amount of hypochlorite produced is a function of the electricity passed directly through the cell. The overall net reaction is:
  • NaCl + H2O → e- → NaOCl + H2
09/14/2007 10:46 AM
How much energy is required to alleviate the hydrogen from the salt solution? Is it less than what is required for water alone?
09/14/2007 10:56 AM
It depends on your anode/cathode size. 4 volts and 10 amps works well on this small unit. At 60 amps it will really cook but a lot of heat is also generated.
09/14/2007 10:58 AM
The salt acts as an electrolyte. You do get more current flow through the water. Yes there is much more activity using salt water compared to fresh water.
09/14/2007 10:12 AM
The video just does not provide enough data to make any judgement about what is going on, making it meaningless.
Bill Morrow
Bill Morrow
09/14/2007 12:09 PM
A fire burning hot enough to split water into H2 and O2 will keep burning when you throw water at it.
Same question as other pointed out: How much energy input and how much we get out of it?
Pineapple
09/14/2007 12:27 PM
The Cuyahoga River used to catch on fire from time to time.
09/14/2007 2:53 PM
One hot, still ,August night we were frog hunting in a small creek. One of the lanterns was dying and John and his brother thought it was out of fuel. They placed it on a sand bar and poured fuel from the good one into the one going out. No funnel around and they spilled as much into the sand as the lantern. 'the fuel seeped into the water and I was thinking as it spread. It wont be long now. then WOOOOOSSSSHHH. The creek was blazing up to their chins....for a second. they were still running after it went out. I will never forget the look on their faces.
Register to Reply 20 comments
-A- (1); 3Doug (1); agua_doc (1); Anonymous Poster (2); bmorrow492 (1); ddk (1); Heath (2); Howetwo (1); rustyh2o (7); willyap06 (3)
