Previous in Forum: Paralleling Conductors Sheeting Effects   Next in Forum: how to measure the distance using SRM400(Sonar Ranging Module)?
Delta versus Wye
09/13/2007 3:08 PM
If you were to connect a motor in delta configuration to a 347volt-3phase system would it have the same power output if it were hooked up in wye configuration to 600volt 3 phase??
Good Answers: 804
Re: Delta versus Wye
09/13/2007 7:40 PM
Yes, provided your motor is wound for that.
AND you find a 347V 3 phase system someplace!
09/14/2007 3:14 AM
Yes.
Aged man is not old man...
09/14/2007 3:47 AM
Yes. Energy consumed would be same irrespective of input voltage excepet some small losses.
Best Regards, Shivaram
New Zealand - Member - New Member
09/16/2007 6:18 PM
Yes, provided that the voltage across the windings is the same, and the frequency is the same, there will be no difference. NB the line voltage is root three higher for a star connection to keep the same winding voltage as delta connection. If the frequency changes, change the winding voltage by the same ratio as the frequency change.
Best regards,
Mark Empson
http://www.LMPhotonics.com | http://www.LMPForum.com
Register to Reply 4 comments
JRaef (1); marke (1); Qqberci (1); shivaganti (1)
