Previous in Forum: Problem During Usage of BOOTP/DHCP Server Software   Next in Forum: Pointer Question
Tetrakaidecahedron Model or Kelvin Unit Cell
06/21/2018 10:13 AM
Hello Friends,
Can someone explain me how to create a tetrakaidecahedron model (Kelvin Unit Cell) using Autodesk Inventor?
Please suggest me an idea to design it?
Kind Regards,
Karthikkumar
Re: Tetrakaidecahedron Model or Kelvin Unit cell
06/21/2018 12:00 PM
Look here.
06/21/2018 12:21 PM
06/21/2018 12:57 PM
..."surface model of a geometrical shape called a "tetrakaidecahedron" which is the approximate geometry of the voids within the metal foam structure.
I gave each of the twelve surfaces a thickness creating a solid model of the geometrical shape.
I then offset the perimeter outline of each surface by a predetermined distance giving a sketch on each face.
The sketch of the offset profile was then extruded by the thickness of the face.
This resulted in something resembling a wire frame model of the Tetrakaidecahedron, which I could then give properties to. Hence giving mass & volume.
I then created an assembly file where I constrained numerous copies of the Tetrakaidecahedron together to form a model equivalent to a cubic measure of the metal foam.
I could then change the offset dimension on the sketch in order to thicken or thin the wireframe member"....
https://forums.autodesk.com/t5/inventor-forum/foam-model/td-p/4383697
https://grabcad.com/questions/tetrakaidecahedron-model
Register to Reply 3 comments
