Previous in Forum: Tetrakaidecahedron Model or Kelvin Unit Cell   Next in Forum: PCS7 vs TIA
Pointer Question
06/23/2018 1:37 AM
i dont understand what diffirent and meaning of (char*)x char *x (char*)&x ..please help me, an example following output is much better.
Re: pointer question
06/23/2018 2:08 AM
06/23/2018 2:28 AM
06/23/2018 2:51 AM
char* is a pointer to the first char in the return "string" (char array). although the size of the array isn't given, in C "string"s are null terminated. meaning you can start reading the chars of the position the pointer is set to until you encounter a null char('\0').
https://stackoverflow.com/questions/9995889/what-does-char-do-or-mean-as-a-return-type-for-a-function
06/23/2018 8:02 AM
In C, different types of data have different size. For example, a character may take 1 byte, a short integer 2 bytes, a regular integer 4 bytes, a floating point number 4 bytes, etc. You have to tell the compiler what kind of number a variable is so that storage can be arranged.
You can also have a null pointer, which tells the compiler that the variable is a pointer which you can assign a size later. If x is a null pointer, you can change it to a char pointer with (char*)x.
To declare x as a character pointer, you assign it as char *x.
If you want to find the address of a variable x, the use &x. To make that address an address to store a character, cast it as a character pointer (char*)&x.
I hope this helps...
Re: Pointer Question
06/23/2018 2:00 PM
The stack is a place in memory where the computer stores temporary data, for example, its current address and variables it is working on when interrupted to do another task. It's usually a program error that causes this area to fill up, hence "stack overflow".
A pointer is a variable that holds an address. The address can be a character, character string, number, structure, etc. An array is a group of characters, numbers, etc. C refers to arrays by their addresses so that it doesn't have to move a lot of data around, hence the confusion between pointers and arrays.
06/24/2018 12:50 PM
pedro54 is a spam bot....haha
06/24/2018 8:21 AM
char* x, char *x,char*x, (char*) x and (char *) x all mean the same, declaring x as a variable of type address, the address being the address of some other variable. &x is the address of the variable x, so you could meaningfully write
char* y = &x;
I hope it is then clear that (char*) &x is not meaningful, as the & itself declares an address.
The bracketed forms are used when "casting", i.e. assigning the value of a variable to another variable of a different but compatible type, e.g.
char* x[] = "ABCD";
char* y = &x; /* the address of x, being that cell in RAM where the A is stored */
int z = (int) y; /* the integer value of the address of x */
char* a = (char*) z; /* a now holds the address of x, and is equal to y */
Register to Reply 7 comments
phph001 (1); Rixter (2); SolarEagle (4)
