Previous in Forum: Future Robotic Process Automation Technology Trends   Next in Forum: Oil from Crankcase Breather
10 comments
RP4 Pump Outlet Size
06/24/2018 6:21 AM
Dear All,
In the given specification of a borehole pump (Grundfos SP 60 -7R), the pump outlet size has been given as "RP4". I would be grateful if someone could help me to understand this size mm.
Thanks & Regards,
Kaushika
Pathfinder Tags: RP4 Pump outlet size
Re: RP4 Pump Outlet Size
06/24/2018 10:49 AM
I'm guessing it's British Standard pipe thread, internal parallel pipe thread, 4"...
"These standard pipe threads are formally referred to by the following sequence of blocks:
  • the words, Pipe thread,
  • the document number of the standard (e.g., ISO 7 or EN 10226)
  • the symbol for the pipe thread type:
    • G, external and internal parallel (ISO 228)
    • R, external taper (ISO 7)
    • Rp, internal parallel (ISO 7/1)
    • Rc, internal taper (ISO 7)
    • Rs, external parallel
  • the thread size
Threads are normally right-hand. For left-hand threads, the letters, LH, are appended.
Example: Pipe thread EN 10226 Rp 2 1⁄2 "
https://en.wikipedia.org/wiki/British_Standard_Pipe
06/24/2018 12:48 PM
06/24/2018 10:21 PM
Dear All,
Thank you very much for helping me.
Thanks & Regards,
Kaushika
06/25/2018 7:41 AM
A simple phone call to the pump manufacturer is all it takes...
06/25/2018 4:52 PM
Asking a question here must be simpler or more enjoyable.
06/25/2018 4:55 PM
It's either answer questions here or head over to the bothy.
06/26/2018 2:48 AM
...and infinitely more time-consuming.
06/26/2018 3:07 AM
Instead of going directly to the source of the information, one can waste time by voting post replies off-topic, for example. It's all in a day's work for some people...
Good Answers: 137
06/27/2018 8:54 AM
But Grundfos might reply that Rp4 (not RP4) is a recognised pipe thread designation, and suggest the OP does his homework .
04/09/2024 7:08 AM
<...Grundfos...> and CR4 might be in agreement, then.
Isn't that what the telephone is for - i.e. to be used for telephony?
A search on the term gives the answer in the manufacturer's image of the pump; it would be best for the original poster to learn how to do research, of course.
Register to Reply 10 comments
Codemaster (1); PWSlack (4); Rixter (1); skaushi (1); SolarEagle (1); tonyhemet (2)
