Previous in Forum: Storage & Preservation of Motors   Next in Forum: Argument for Biomass
25 comments
Hobbies - Musician - New Member Greece - Member - New Member
The Mysteries Of The "Infinity" (Part 2)
09/17/2007 10:07 AM
Hello again…
This post is a continue sequel of my previous post: "The Mysteries Of The Numbers "Zero" And "Infinity"" (12/9/07)
In this post (and during the discussion) I claimed (or proposed) the following things:
("n" is any finite number)
A) "n/0" has "no meaning" and is not allowed (and is not ∞ )
B) "0. ∞", maybe, is "unidentified" (but not "indefinite", as this should mean that "0. ∞ = n" which gives "n/0 = ∞" (and that's wrong due to (A) )
C) "∞/0"=??? (the result can't be neither "n" not "0" as both multiplied by "0" gives "0" and not "∞"… if the result is "∞" this gives "0. ∞ = ∞" which is wrong if (B) is correct… so what's the result???… is this unidentified too???…)
D) "∞/∞ = n" (the result is "indefinite")… (I'm not sure, though, that "∞/∞" can, also, give "∞" under all circumstances... I'll present you some of my thoughts...)
Note that all the above are my personal opinions and those are not for certain…
(In fact some issues such as "n/0" or "0. ∞" are under discussion between the mathematicians)
During the discussion Tasos (Tkot) had some doubts:
"Likewise, to say that ∞/∞ =n yields ∞.n=∞ is not as obvious as it seems at first glance, as in order to pass from the one equation to the other we need to multiply both sides of the first one by ∞, i.e. ∞.∞/∞=∞.n and I wonder how the annihilation will go on to give the ∞ = ∞.n…"
In a matter of fact, I agree with him… The arbitrary manipulation of the "infinity" can give us arbitrary results… So we must be careful with the manipulation of the "infinity" …
So there is a question if the "∞.n=∞" and "∞/∞ =n" are valid and equivalent…
Now, I would like to continue my thoughts:
Let's take the set of the natural numbers: A={1,2,3,…}
a) We can have the following subsets of A:
A1={1,3,5,…} and A2={2,4,6,…} Then A1+A2={1,2,3,…}=A
(this means (concerning the elements of A) that: ∞+∞=∞ thus 2.∞=∞)
b) We can have the following subsets of A:
A1={1,11,21,…} , A2={2,12,22,…} , A3={3,13,23,…} … A10={10,20,30,…} Then A1+A2+A3+…+ A10={1,2,3,…}=A
(this means that: 10.∞=∞)
c) We can have the following subsets of A:
A1={1,101,201,…} , A2={2,102,202,…} , A3={3,103,203,…} … A100={100,200,300,…} Then A1+A2+A3+…+ A100={1,2,3,…}=A
(this means that: 100.∞=∞)
All the above show not only that "n. ∞ = ∞" , but also that "∞ / n = ∞" because the same infinite set (the A) can be separated in any finite number (n) of infinite subsets (and if we add all these subsets we get, again, the A)
But what about "∞/∞"???…
Consider, again, the above cases (b) & (c)… we can, further, "shatter" the A as in the next case:
d) We can have the following subsets of A:
A1={1,1001,2001,…} , A2={2,1002,2002,…} , A3={3,1003,2003,…} … A1000={1000,2000,3000,…} Then A1+A2+A3+…+ A1000={1,2,3,…}=A
(this means that: 1000.∞=∞)
You see that, as the number of the produced subsets is increased, each subset has "fewer" elements (although each subset, still, has infinite elements)… or you could say that each subset becomes more and more "sparse" (concerning its elements)… So, we can continue this procedure infinite times… In this way, we produce infinite number of subsets and each subset is infinitely "sparse"… I don't even know if each subset has any elements at all (except, perhaps, the A1 subset which begins with "1" , e.g. A1={1,…})…
So, I can't get a result for the "∞/∞"…(???)…
Another way (to consider these issues) is the following:
We have a part of a straight line (of any length)… It has infinite number of points… We can divide this part by any finite number (n), producing "n" new (and smaller) parts and each of them, also, has infinite number of points (no matter how small are these new parts)… So we have that: "∞ / n = ∞" (concerning the number of points)… Of course we can add all these smaller parts and recostruct the initial part, hence: "n. ∞ = ∞" … [Also, note that it doesn't matter how small is the initial part… It can be extremely small… You can, further, shatter this tiny part producing any number of tinier parts (each of them having infinite points)…]
The problem arises when we shatter this initial infinite part infinite times, producing an infinite number of "infinite small" parts… Can we consider this "parts" as "points" or as "extremely tiny parts of zero length"???… So, in this case we cannot estimate the "∞/∞"…(???)…
But if we consider "a straight line of infinite length" then, of course, we can shatter this line producing infinite parts of any length (and, of course, each part has infinite points)… Thus: "∞/∞ = ∞"… And we can recontruct the initial line by adding all these parts, hence: "∞.∞ = ∞" … So we come to a conclusion that "a part of a straight line" and "a straight line of infinite length" are not "infinities" of the same kind (or "size") (although both have infinite points)… We could consider the "straight line of infinite length" as kind of a "larger infinity" (than the "part of a straight line") because, in this case, the expression "∞/∞ = ∞" is valid…
These were my thoughts… I would like to have your comments…
George
Location: The cigarette-stained drunkard living in the cardboard box outside Marks & Sparks delivery entrance, Eastgate Shopping Centre, Basildon.
Re: The Mysteries Of The "Infinity" (Part 2)
09/17/2007 10:29 AM
Will this discussion → ∞ ?
Strewth!
Essex jobs for Essex yobs! <Burp>.
Good Answers: 918
09/17/2007 11:24 AM
Help! I am lost in infinity. If you divide any number by itself you always get 1. Why not, then: ∞/∞ = 1 ? When you say ∞/∞ = n, does that not imply that one man's infinity is bigger than another's?
09/17/2007 11:48 AM
<does that not imply that one man's infinity is bigger than another's>
No. That's indeterminate. <Splutter>
09/18/2007 7:21 AM
"we can shatter this line producing infinite parts of any length (and, of course, each part has infinite points)… Thus: "∞/∞ = ∞"
If you divide the line into infinite parts you are not dividing by ∞, you are then dividing by a number which is approaching zero. Therefore ∞/0 = ∞.
09/18/2007 8:22 AM
Hi, Poison...
You have a "line of infinite length" (of course, it consists of infinite points (i.e. "∞ points")... Then you divide this line infinite (∞) times and, so, you get infinite equal "parts" of this line... Each of these parts can have any finite length (it can be as short or as long as you want) and, of course, it consists, also, of infinite points (i.e. "∞ points")... So, you have: "∞ points" / ∞ = "∞ points" ... Hence: ∞/∞=∞ ...
(The opposite: You have "a part of a line" (which consists of "∞ points")... You multiply this part by ∞ (i.e. you add infinite such parts) and, of course, you get a "line of infinite length" (which, of course, consists of "∞ points")... So, you have: "∞ points" . ∞ = "∞ points" ... Hence: ∞.∞=∞ ... )
George
09/18/2007 11:13 AM
Note, though, that the "∞/∞=∞" seems to be valid in the case the "line of infinite length" that I mentioned before... But in the case of the "part of a line" (which has finite length but, also, has "∞ points") I cannot say that the "∞/∞=∞" is valid... As I said (in the initial post) if we divide such a part by "∞" we get an infinite number of "infinite small" parts... If we consider such an "infinite small" part as a "single point" we could say that: "∞ points" / ∞ = "1 point" thus "∞/∞=1" ... But if we consider such an "infinite small" part as a "part" (although an extremely tiny one) we could say that: "∞ points" / ∞ = "∞ points" thus "∞/∞=∞" ... The problem is I don't know how to perceive this "infinite small" part: as a "single point" or as a "part" ???...
(It is the same problem as with the "sets" that I mentioned in my initial post: The infinite subsets (i.e. A1, A2, A3, ..., A∞) that we can produce from a set (i.e. A) (where A is the union of all those subsets)... In this example I saw that A1={1,...}, A2={2,...} e.t.c., so the A1 seems to have just one element (the "1"), the A2 seems to have just one element (the "2") e.t.c.... How can I consider all these subsets: as "single numbers" or as "subsets of numbers" ???... It is a similar question as before...)
As a matter of fact, I doubt about my initial perception (see (D) in my initial post) that: "∞/∞=n"...
So I have to reconsider this... Afterall, it seems that in some cases (such as the infinite division of a "part of a line") the "∞/∞" has "no meaning"... I really don't know...
George
Hobbies - Musician - guitar fan Greece - Member - Engineering Fields - Software Engineering -
Good Answers: 18
09/18/2007 11:00 AM
Right, it's not allowed in the number system of the reals, because there is no number WITHIN the set of reals with which we can multiply 0 to get n. As simple as that. If we extend the reals to include the ∞, then we DO get n/0=∞, only that we have to trade off some of the nice properties of the number system of reals (OK, someone might say, "who cares?"). Otherwise we can only approach infinity using limits of sequences.
If we approach infinity arithmetic in the more relaxed way we are doing throughout this discussion, then indeed these two equations are equivalent and valid, BUT, as long as we are talking about infinities of the same order, or more technically, of the same cardinality. For example, if you divide the infinity of the reals (e.g. the points in a line) by as many time as the number of the integers, then you get infinity again. (If you do the inverse, you get 0.)
Referring to your train of thought involving dividing a line infinite times, it seems that what you do is dividing a higher order of infinity (2nd order maybe) by a countable infinity (i.e. 1st order), that's why you get infinity as a result. Try instead to divide the line by as many times as the total number of the reals, in which case you'll get infinite pieces of finite point long lines! But even if you are an eternal and never-getting-bored being (and there is no Big-Crunch, and...), I doubt you can divide the line so many times as many are the reals!
It is not so. Each part of a straight line has as many points as any other part or even as the whole line itself. It can be easily shown that each point of the part can be mapped one-to-one with each point of the whole.
As I said before, the expression ∞/∞ = ∞ is valid when the numerator is infinite of higher cardinality. Otherwise we cannot tell, unless we know the sequence that limits to this expression: in this case, the result depends on the relative rate at which the infinities in the numerator and denominator are approached.
tkot
Popular Science - Cosmology - New Member United States - Member - New Member
09/18/2007 4:21 PM
Hi tkot,
IMHO ∞ is not a number (NAN) and cannot correctly be used in an equation as a number. While it can be shown that the result of an equation, if carried to its ultimate conclusion may result in ∞ such as, for example:
lim x -> n 1 / (x - n) = ∞, this is not the same as using ∞ as a number such as ∞/∞, although symbolically, as I think you pointed out, the symbol ∞ can correctly by used to represent sets and sub sets.
I believe that infinity does represent a situation in where the laws of physics and mathematics break down, such as in equations that deal with QM, M-theory, cosmology, etc.
So you could probably say that ∞ can represent the destination where the singularity (in a BH or at the BB) resides, or simply ∞ = singularity.
Still, it's NAN and cannot be treated as one.
-John
All worthwhile programmers know that constants always vary.
09/19/2007 4:33 AM
Hi Tasos...
"Referring to your train of thought involving dividing a line infinite times, it seems that what you do is dividing a higher order of infinity (2nd order maybe) by a countable infinity (i.e. 1st order), that's why you get infinity as a result."
By saying "1st order infinity" you mean i.e. the set of the natural or integer numbers???... And by saying "2nd order infinity" you mean i.e. the set of the real numbers???...
"Try instead to divide the line by as many times as the total number of the reals, in which case you'll get infinite pieces of finite point long lines! But ..... I doubt you can divide the line so many times as many are the reals!"
The total number of the elements of the "set of the real numbers" is obviously infinite (∞)... So you just divide the "line of infinite length" by "∞"... I don't get what you are trying to say... And by dividing a "line of infinite length" by "∞" how do you get infinite pieces of finite point long lines???... What "finite point long lines" means???... Is it obvious that each of these line parts (that are produced) have infinite points???... (So I need a clarification)...
I said: "We could consider the "straight line of infinite length" as kind of a "larger infinity" (than the "part of a straight line") because, in this case, the expression "∞/∞ = ∞" is valid…" ... You said:"It is not so. Each part of a straight line has as many points as any other part or even as the whole line itself." ... I agree... Both consists of infinite points... But are they "similar infinities"???... Are they of the same "size"???... And if so, how we get "∞/∞=∞" in the case of the "line of infinite length" but not in the case of the "part of a line"... Pls, read carefuly my posts #5 & #7... Am I wrong in sth???...
George
Good Answers: 18
09/19/2007 5:58 AM
Hi guys
There are different orders of infinities. Infinities are classified by the their so called cardinality, which shows how many members are in a particular infinite set. For example the number of the naturals 1,2,3... are classified as infinite of order 1 (or Aleph-1). Another way to cal this infinite is "countable" because you can put all numbers in a row and assign an index number to each of them. Same cardinality has the set of rationals, or the set of even integers and so on.
On the other hand, the cardinality of the set of real numbers is something more than that. If you try to put these numbers in a row and say "this one is the first, this one is the second, ..." you will find that there will always be another one in between any two of them. This set is not countable. It is certainly of higher order, most probably of 2nd order (or Aleph-2) although this has to be proven. (You can go on and imagine even higher order infinities, like e.g. Aleph-100 or Aleph-Aleph-1 or Aleph-Aleph-Aleph-.....infinite times.... -Aleph-1. Or Aleph-Aleph^Aleph^... Oops, I got dizzy...)
When you divide a line, what you do is divide it by, say, 10 or 100 or 1000. You get pieces that can be arranged one after the other, so you have a countable set of pieces. Now if you go on dividing more and more, eventually reaching infinity, then what you do, is to divide the Aleph-2 points of the line by Aleph-1 times. What you get is Aleph-1 pieces of line with still infinite (Aleph-2) points each!
Of course, you cannot divide the line by Aleph-2, given we agree what line division means in our context. IF you did, then you could have separate points - as I said in my previous post - but I cannot see how this division can be done. Even if this was technically possible (how?), still it wouldn't suffice even Aleph-1 time to perform, even if you could make Aleph-1 divisions every second!
As for the number of the points in a finite length of line as compared to the whole line of infinite length, they are the same. The trick used when talking about cardinalities, is to map one-to-one each member of one set to each member of the other, and if such a map exists, then you establish that the sets have the same cardinality. In our case, consider the line length between the points 0 (0 not included) and 1 and the line between 1 and ∞. You can easily device map(x)=1/x to prove that each point in the one part has one and only one counterpart in the other.
Infinity is a thrilling topic, although very difficult and I cannot touch it any deeper. But what I understand, is that infinity doesn't mean "just everything". There are certainly things that are not included, even in an infinite set of things. And there are things you cannot do even with infinite power or infinite time. I wish Douglas Adams were right when he claimed that in an infinite and eternal universe you will sometime and someplanet eventually find screwdrivers growing from the trees...
tkot
Good Answers: 18
09/19/2007 6:30 AM
Oops, I discovered a mistake in my previous post. I should have started the Aleph classification with index zero. That is, a countable infinity has in fact cardinality Aleph-0, the set of real numbers Aleph-1 and so on.
tkot
09/19/2007 7:43 AM
Thanks, Tasos... Nice analysis... It helped a lot...
According to your analysis a "line of infinite length" and a "part of a line" are sets (of points) of the same cardinality (probably Aleph 2)... So, in my procedure I was dividing both of them by an "Aleph 1" infinity (the "∞" of the natural numbers)... As such a division of a "line of infinite length" gives infinite number of "line parts" (each of them having any finite length and infinite points), thus "∞/∞=∞", the same must happen for the case of the "part of a line"... e.g. such a division of a "part of a line" must give infinite number of "line parts" (each of them having infinite points)... Thus the result of such a division must be "parts" (although extremely small) and not "points"... So, we should consider again that "∞/∞=∞"... Am I right???...
George
09/19/2007 7:50 AM
Oops, now I saw your correction... (Assume the same in my previous post)...
Anyway, I wait for your reply...
George
Good Answers: 18
09/19/2007 8:24 AM
In the context we are talking about it is ∞/∞=∞ indeed, but to be more accurate we should have written instead: Aleph1/Aleph0=Aleph1. Things are much clearer now. The symbol ∞ denotes generally the infinity which is relative to the context at hand (mostly the Aleph0). But when it is used in the expression ∞/∞, we lose information about what exactly is the nominator and what is the denominator. They are not the same entities in our example!
tkot
09/19/2007 8:41 AM
I totally agree... I still need your opinion in my message #12...
George
09/19/2007 9:04 AM
Let's put my message #12 in the correct terms:
The number of points of a "line of infinite length" is Aleph-1... I divided it by Aleph-0 (the "∞" of the natural numbers)... The result is [Aleph-1]/[Aleph-0]=[Aleph-1]... (this is the more precise expression of the "∞/∞=∞" that I said before...)
The number of points of a "line part" is, also, Aleph-1... I divided it by Aleph-0 (the "∞" of the natural numbers)... The result is [Aleph-1]/[Aleph-0]=[Aleph-1]... (this is, also, the more precise expression of the "∞/∞=∞"...)
Am I right???...
So, it seems that all these infinite "extremely tiny line parts" that are produced by such a division of the "line part" (by the "∞" of the natural naumbers) gives Aleph-1... which means that we must concider these "extremely tiny line parts" as "parts" (with infinite points) and not as "single points"...
Do you agree???...
George
Good Answers: 18
09/19/2007 10:05 AM
Exactly! In order to get single points, you need to divide the line by Aleph-1, which is not possible as I understand. Dividing a line, as we mean it, is separate it in smaller consecutive regions, something like cutting a string by the scissors. This method can only provide us with at most Aleph-0 cuttings.
tkot
09/19/2007 10:42 AM
That's nice... So, let's finish it...
Assume that we have a "line part" (or a "line of infinite length"...it doesn't really matter as they both are Aleph-1)... Then if we could divide it by Aleph-1 (e.g. the "infinity" of the real numbers... suppose that we could do it with a magical way...) then the result would be 1 (I mean just one point) or n (I mean a "line part" which consists of "n points", where n is any finite number)???... What do you think???... I would dare to say that it doesn't matter... Afterall, what is the meaning of a "line part" which consists of some (finite) points???... (I, really, cannot perceive such a "part")... So, we could assume that [Aleph-1]/[Aleph-1]=n ... (This is a general or indefinite result)... Do you agree with this???...
George
Good Answers: 18
09/20/2007 3:30 AM
It is not possible to have a compact line part consisted of finite points. You can always find new points in between each pair of those, and this story goes on to infinity! If one could divide a line to Aleph-1 parts, I had in mind that the result would be some scattered individual points, not line lengths. Of course, by cutting the line the way we are talking about, i.e. choosing a point on the line which separates it in two parts, the left and the right, and then cut again and again, what we get is a countable set of line parts, therefore, their number will be no more than Aleph-0. If someone knows a method by which we can divide a line in Aleph-1 parts, is welcome to put it forward.
Of course, Aleph-1/Aleph-1 is not necessarily a number n as you said. It can also be Aleph-0. If we cut a line on every e.g. integer point then we will have: (points of whole line)/(points in each part) = (number of parts) or A1/A1=A0.
tkot
09/20/2007 4:50 AM
Ah, yes... I agree with all of these...
What about Aleph0/Aleph0???... The result is "n" (e.g. any finite number)???...
George
09/20/2007 6:32 AM
[ By the way, after your analysis, I realized that the other example that I gave in my initial post (the division of the set of the natural numbers (A) by the "∞" of the natural numbers) actually will give as a result individual numbers (and not subsets)... With the procedure (that I presented) we produce subsets A1, A2, A3, ..., A∞ that are A1={1,...}, A2={2,...} e.t.c., The A1 seems to have just one element (the "1") as the second element should be in an "infinite distance" from the "1", so, actually this subset is A1={1} (and in the same way we have A2={2}, A3={3} e.t.c.)... So, we have that: "infinite elements"/∞ = "1 element" ... Thus, in this example, we have "∞/∞=1" (with the meaning of Aleph0/Aleph0=1)... But I suppose that we could produce the infinite subsets in another way also... I.e. in my initial post I could produce the subsets as follow:
A1={1,2,11,12,...}, A2={3,4,13,14,...}, ….. , A5={9,10,19,20,...} (thus producing 5 subsets)
Then if I follow the procedure of the "spacing out" of the subsets (producing more and more subsets), as in my initial post, then I get:
A1={1,2,...}, A2={3,4,...}, ….. or, actually: A1={1,2}, A2={3,4}, …..
Which gives "infinite elements"/∞ = "2 elements", hence "∞/∞=2" … With the same way, by making the appropriate subsets, I could get: "infinite elements"/∞ = "n elements", hence "∞/∞=n" … I think that's a good way to perceive that Aleph0/Aleph0=n (where n is any finite number)… Don't you think???… ]
Hence, we have the followings:
Aleph0/Aleph0=n
Aleph1/Aleph1=n or Aleph0
Aleph1/Aleph0= Aleph1
So, as a conclusion, we can say (in a more relaxed way) that the expression "∞/∞" may gives as result "n" (as it may be "n" in the case of Aleph1/Aleph1 or it is "n" in the case of Aleph0/Aleph0) or "∞" (as it may be "Aleph0" in the case of Aleph1/Aleph1 or it is "Aleph1" in the case of Aleph1/Aleph0)... Don't you agree???...
George
Good Answers: 18
09/20/2007 8:53 AM
Aleph-x/Aleph-y =
  • Aleph-x, if x>y
  • 0 , if x<y
  • indeterminate value <= Aleph-(x-1), if x=y
tkot
09/20/2007 9:25 AM
Hence what I said before:
Aleph0/Aleph0=n
is correct... Isn't it???...
George
Good Answers: 18
09/24/2007 10:09 AM
Yes.
You can also check some few references here:
http://www.earlham.edu/~peters/writing/infapp.htm
http://www.earlham.edu/~peters/writing/infinity.htm
http://mathworld.wolfram.com/CountablyInfinite.html
http://mathworld.wolfram.com/Aleph-0.html
http://mathworld.wolfram.com/Aleph-1.html
tkot
09/25/2007 5:43 AM
Thanks, Tasos...
George
Register to Reply 25 comments
Anonymous Hero (1); G.K. (12); Johnjohn (1); Poison (1); Stinky Pete (2); tkot (8)
You might be interested in: Test Points, Parts Feeders
