Previous in Forum: 3VA PT/VT Measurement and Safety/Accuracy   Next in Forum: Excitation Problem with Parallel Operation of Turbo Generator
10 comments
Delta Connected Motor to VFD
07/01/2018 4:52 PM
We have six terminal outgoing terminals from a VFD to a motor. It means the motor is delta connected. why not the Motor have a Delta winding Internally or delta connected through links or through cables. why we need to run a cables from the VFD to the motor for making a delta connection?
Re: Delta Connected Motor to VFD
07/01/2018 7:36 PM
Why six wires? Maybe so you can easily read or monitor the current in each motor winding.
07/01/2018 7:43 PM
If it is not stolen, it should have come with an operator's manual. That is likely to have a wiring diagram.
If not, ask the manufacturer for one.
If all else fails, hire a tech that knows VFDs and motors.
07/01/2018 8:32 PM
I think you have some faulty information....what is the VFD brand and model #? Is this a 2 speed motor? Is this the original motor? What other info do you have on the motor? What type of equipment is this on?
Good Answers: 117
07/02/2018 2:54 AM
Are you sure its a VFD and not a StarDelta starter?
07/02/2018 11:48 AM
I have attached the terminal details of VFD in the link,
https://www.dropbox.com/s/syemub2szqbdv2e/Power%20and%20control%20cables%20arrangement.pdf?dl=0
The load is a compressor Motor. I don't have the motor drawings. The VFD make is Fuji Electric's Frenic Eco Series
Good Answers: 804
07/02/2018 12:58 PM
It appears as though that inverter was modified to run two motors from the one inverter. If you look carefully, each of the terminal pairs is labeled the same: U1, V1, W1.
07/02/2018 2:49 PM
JRaef,
If you closely look at the right side terminals, (Y, X, Z) is written in that attachment, which implies that it is a delta connection. Sample image below,
Good Answers: 804
07/02/2018 8:05 PM
I think you are reading too much into this. But what do I know? I’m not there...
Good Answers: 22
07/03/2018 2:26 AM
The 6-terminals at motor may not be for Delta connection.
Could it be that the motor has two windings internally!
The 'One-channel 12/12 -pulse series connected LCI drive' supplying the two windings!!
Could you get hold of the motor winding connection diagram (Motor name plate may have it)!!
Raghunath
07/14/2018 2:22 AM
Are sure the 6 terminal are for the motor winding?..
Anonymous Poster (2); brich (1); JRaef (2); lyn (1); raghun (1); Rixter (1); Simon Wan (1); SolarEagle (1)
