Previous in Forum: Solar energy and cooling systems   Next in Forum: Concentricity of a D Fork in a Knuckle Joint
Question About Bearing Preloads for A CNC Machine
09/17/2007 12:47 PM
How much bearing pre load to be given for axis bearing(ball screw) for a cnc machine feed rate level as 60meter/min.
Re: Question About Bearing Preloads for A CNC Machine
09/18/2007 8:57 AM
How about following the manufacturers instructions, always a good place to start. Or when all else fails follow the manufacturers instructions
Failing this, get in contact with the manufacturer whom I feel would only be too pleased to furnish the required information.
United States - Member - New Member Popular Science - Weaponology - New Member
09/21/2007 2:14 AM
I can't tell you in inch/pounds, for that you would have to contact the bearing copany or talk to an engineer at a compny such as Hardinge in Elmira Ny. They really are the experts at this.
I worked at a company that built retrofit mills, and we always did it by feel. As long as you can still turn the ball screw by hand (grabbing the actual screw with your hand not a wrench) it is not too tight. After the machine is operational, measure the backlash. It should be less than .0002 or something is not quite right. That something may or may not be the bearing.
Men are like steel, if they lose their temper they are worthless.
