Previous in Forum: Dissipating heat from future chips   Next in Forum: Is CG iron superior to Grey iron
Air pressure inside pipes
04/19/2005 12:43 PM
Alexandre Lanza writes:
How can I calculate the internal diameter of pipe to link an air compressor to a pick-in-place machine, knowing that the machine-compressor distance is 80m, the compressor supplies 6 bar, and the machine needs up to 283 liters/minute at 6 psi?
the easy way
04/19/2005 11:31 PM
The easy way to get a rough estimate is to use Bernoulli's Equation...
(P/rho + (V^2) / 2 + g*h), 1 --> 2 = 0
where P is flow pressure, rho is fluid density, V is mean flow velocity, g is the acceleration due to gravity, h is the flow height relative to some reference height, and 1 --> 2 means that you need to evaluate this sum at two points in the flow (i.e. at the pump and at the machine) and then take the difference. You can write the velocity in terms of the volume flow rate and the diameter, and then solve for diameter (everything else should be known).
Bernoulli is essentially an energy balance, and it doesn't take into account any sort of turbulence or friction (so-called turbulent drag). In addition, it strictly only applies along a flow streamline... which you won't have in turbulent flow. As your pipe is quite long, frictional head loss will probably be large and I want to emphasize that this is definitely a ROUGH estimate.
For the more exact solution, you need to deal with friction factors and Reynolds numbers. I can explain it if you're interested, but it's more of a hassle and will probably involve some numerical iteration to get an answer... let me know.
C
United States - Member - New Member Fans of Old Computers - PDP 11 - New Member Hobbies - HAM Radio - New Member
Re:the easy way
04/20/2005 3:15 PM
Does the orientation of the pipe matter for this solution to work? (e.g., vertical in the gravity field, or horizontal)?
Re:the easy way
04/20/2005 3:24 PM
No... the (g*h) term accounts for any changes in elevation relative to gravity.
C
Re: Air pressure inside pipes
03/23/2008 8:00 AM
You would require 1/2 inch pipe upto the pressure regulator.
Keep the length of pipe having 6psi pressure (output of regulator) as close as possible to point of use, and that will be a minimum of 3 inch.
Cheers.
He must be very ignorant as he answers all the questions he is asked. Voltaire
chaterpilar (1); cmac (2); Steve (1)
