Hi!
Our company has to choose between two
instruments but we did not have the time to test both of them properly. We are about to
buy a vector network analyzer that has a frequency range up to 40 GHz. The first one is an Anritsu 37369D, the other is an Agilent N5230A. The Agilent is a newer
design but there is a difference in the results measuring the same device. We design
passive microwave components and it is quite annoying that the difference is in
the loss measurement. It is just a tenth of a dB but this is one of the most important
parameters for a passive device.
The Agilent indicates more than the Anritsu. We
have another Anritsu that has a frequency limit of 6 GHz and under this limit
the two instruments from the same manufacturer indicate the same results.
Do any of you have some experience with these
instruments? I would appreciate any suggestion that helps to choose.
